    Senior Member Three Rings tarunpatel's Avatar
    Jul 11 2008
    Surrey, B.C.
    Help How to change Miles into KM and F-Celsius
    Hey there just bought a 2006 A4 2.0T from California and I live i Vancouver Canada does anyone know how to chage the MILES into KM is there a button you hold~ Also the Temp how to change the Fahrenheit into Celsius thanks so much!~
    Registered Member Two Rings navi604's Avatar
    Mar 20 2008
    Vancouver
    Re: Help How to change Miles into KM and F-Celsius
    Hold Circulation and + button together to change the Fahreheit to Celsius. As for miles to KM... I think you can change that in the menu...
    Junior Member Two Rings Audine's Avatar
    Aug 27 2008
    Vilnius, Lithuania
    Mine A4 miles to km conversion was done in local audi dealership with VAG ( I live in Europe ). As far as I know you can't do that without plugging car to VAG . Just want to let you know about some central lock problems, that after that conversion if I lock the doors from inside I can no longer unlock them with unlock bottom, so you can only open doors by mechanically pulling the door handle twice (this sucks, but I got used to that) . I was told in dealership that this is the common problem with american audi's which can not be solved..
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Quote Originally Posted by tarunpatel View Post
    Use the right stalk to navigate the menu in your cluster to change the miles to kms and vice versa.
    Apr 09 2008
    Boulder, CO
    My display units were associated with the key. One key displayed Fahrenheit and the other Celsius.
    Just had the dealership reprogram the key so they both display Fahrenheit.
