Results 1 to 13 of 13
Thread: the suck!
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    the suck!
    i replaced my timing belt and all accessories ~12k miles ago.
    yah well im driving the other day and in boost i see this smoke coming from under the hood. immediately stop the car and look to see wtf is going on and after some blank troubleshooting i pull the timing cover back and my timing belt is loose enough to pull off the sprocket!
    turns out my timing idler pulley went to shit. the bearings were shot and the belt was rubbing against the plastic cover. in addition to that the water pump makes a nasty noise (like that of a whale) when spun by hand. fuckin sucks but at least i didnt jump a tooth... thank God!
    damn 2.7T's
    p.s. the water pump was branded "hepu" .. was listed OEM on the parts site i order from.. not sure what the pulley was
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: the suck!
    where did you buy the pump from?
    Also I hope you dont drive it another foot until you fix it. Hate to see the belt go and bend the valves.
    Sorry to hear about the problem.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    Re: the suck!
    That sucks man... where did you get the parts from? Blauparts.com has great prices on stuff and it's all OEM.
    Josh
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: the suck!
    i bought them from a wholesale oem supplier ... not a commonly known site. anyways being that i didnt know what the smoke was coming from i drove the car another 4 miles home. the bearings were grinding like a mf. i was like damn its 4 am ..should i get it towed? nah just drive it slow home. next day i found the timing belt was loose.
    im LUCKY
    Mar 14 2007
    Phoenix Arizona
    Re: the suck!
    No kidding! I would not buy parts from that site again btw. Just my $.02
    Josh
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Re: the suck!
    Quote Originally Posted by ThePaintballGuy View Post
    Josh
    Porque?
    Nov 27 2007
    2000 s4 black : 03 600rr Black
    NOVA, VA
    Re: the suck!
    Quote Originally Posted by grAh4m View Post
    Porque?
    ^^^=why?
    Jun 14 2007
    2000 S4
    Connecticut
    Re: the suck!
    so it doesnt happen again ? lol
    I ordered my kit from ECS tuning it was the ultimate super duper kit for 350. Its nice. haha
    I can SECOND for Blau parts. Got all those parts when my brother needed the tbelt done on his 2.7TT A6 and really nice OEM shiznit. same as ECS pretty much
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: the suck!
    werd. the pump i ordered this second time around (from teh same site) is blau.
    no more hepu!
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    Re: the suck!
    is the impeller plastic or metal. someone was telling me oem pumps are crappy because they use plastic impellers yet some aftermarkets use metal. just a thought.
    Jun 14 2007
    2000 S4
    Connecticut
    Re: the suck!
    Quote Originally Posted by nizmosx View Post
    thats true... even if you go to audi though the revised water pump is a metal impeller rather than the plastic one that failed sometimes... that was revised by audi even they knew they effed that one up haha
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: the suck!
    the pump i bought that failed had a metal impeller.
    Feb 17 2004
    Sterling, VA
    Re: the suck!
    I'm surprised that the Hepu failed. I've used those before for years at a time with no problems.
    I'd bet that the pump started seizing up and the belt was being stretched from the added heat.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
