Results 1 to 7 of 7
    Senior Member Two Rings upstateavant's Avatar
    Jan 09 2008
    99.5 A4 Avant 1.8T, 04 325i
    Poughkeepsie, NY
    Strange Starting Issue?
    I couldn't find a thread similar.
    The other day my car wouldn't start on the first try. I turned the key and I could hear the starter motor spinning but it seemed to not engage the engine. Second try it started normally. This is becoming a more frequent problem. Seems to only happen when the engine is cold. It start first try after the car is warmed up.
    I'm assuming I have a bad starter, but want to make sure. Has anyone had a similar problem. Thanks.
    99.5 A4 1.8T / GT28RS Eliminator / MTM Stage 3 ECU / APR Exhaust / Test Pipe / Southbend OFE Stage 4 Clutch / Unorthodox Lightened Flywheel / UUC Motorwerks Short Shift / 5 Bar FPR / Stratmosphere BPV / K&N Air Filter / Koni Shocks / Neuspeed Race Springs (Front) / H&R Sport Springs (Rear) / Neuspeed Rear Sway Bar / 18" Flik Wasps / Falken FK-452 Tires / Turbo Timer / VDO Center Mount Boost Gauge / 200K Club.
    Veteran Member Three Rings oldblu's Avatar
    Jan 01 2008
    Budd Lake, NJ
    Re: Strange Starting Issue?
    You may not be getting the same amount of cranking amps when it's cold. Every battery doesn't crank as many amps when it's cold. That's probably your issue.
    Does it slowly start up?
    --Silver 2000 A4 2.8L V6 Quattro
    S4 Bumper. Borbet Type LS Wheels. M3 Replica Spoiler
    Blue! How come there's no ice
    in my lemonade?
    Dec 30 2007
    wilmington nc
    Quote Originally Posted by upstateavant View Post
    sounds like the solenoid isnt working properly maybe take it apart and clean or just replace it....Im not sure on cleaning it because Ive never taken one of our apart or had it in my hands but Ive rebuilt countless starters in my diesel class
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    i bet its your battery dying
    Jan 01 2008
    Budd Lake, NJ
    ^ People really overlook the battery, don't they?
    in my lemonade?
    Jan 09 2008
    Poughkeepsie, NY
    maybe its the battery, but when it does start it sounds completely normal, no strain at all and the lights don't dim.
    Oct 10 2008
    orland park
    I dont know much, but ill chip in. Teeth on the starter / flywheel? I had a car where the flywheel was missing a few teeth and the starter would spin. If it happends again, id take the starter our and check it / bench test it. just my 2 cents
