Results 1 to 14 of 14
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Replacing turbo's without removing engine???
    Has anyone replaced their turbo's without pulling the eingine on our B5S4's?
    I was talking to a mechanic today who works on audi's and just asked if he ever replaced turbo's on our cars. he said a few.
    I told him how if I ever had to I was going to try and tackle the job myself but wasnt looking forward to pulling the engine, and he asked me why I was going to pull the engine.
    I was surprised because I guess I thought you had to. but he said that if you take dp's off and take out half shafts you can get them out without pulling the engine. He said he made up some special tools to get to the bolts on the turbo's. But he said he has done it that way a few times on both a B5S4 and on a A6 with 2.7T
    He said he even put K04's back in place of the k03's.
    So I was wondering if anyone else has done that? And thoughts on that.
    sounded like a good idea to me.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Re: Replacing turbo's without removing engine???
    heard of it done before also. most change the motor mounts, clutch while they are at it so its more standard to yank the entire engine.
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    I almost think it would just be easier to pull the motor. More room to work, make sure that everything is on tight, ect.
    Josh
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Josh did you end up putting new turbo's in when you did all that engine work.
    I dont remember just remember you had to redo the heads
    Mar 14 2007
    Phoenix Arizona
    No, I didn't have the money too. But they seem to be doing well! I am making 15psi and no weird noises or anything like that. Hold strong and everything!
    josh
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Thats cool.
    But back to original topic, that does make sense to put new clutch and engine mounts.
    I guess my stock clutch is running strong. so dont see need for that (although k04's would put more stress on it) but I dont track it (ok ok I did track it once, but that is last time) and I dont launch it so it should be good for awhile yet.
    About the engine mounts. I thought I read you can replace those as well without pulling engine. Is that possible? maybe I'm wrong.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by gointoscott View Post
    It's possible, lots of stuff has to come off, but you can change them without an engine pull.
    08 S4- Stock SOLD
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    not this topic again.
    .rollseyes.
    Apr 18 2007
    b5 s4 nogaro , 1991 bmw 325is 5spd
    florida,wellington & hollywood
    plz let this be the las post ! i did it with the engine in the first time ,..... and would NOT recommend this i had to use tools i've never heard of (luckily a god friend let us use his shop) and it was such a bitch to get the turbos out ... just yank the motor its not that hard i did it in 9 hrs alone and it was my first time :) plus you can see what else needs to be done and can also wash engine bay lol
    cheers
    --daniel
    Jan 29 2007
    08 S4 00 S4
    MD
    To clarify...I was talking about replacing engine mounts without pulling the engine..
    Last post
    08 S4- Stock SOLD
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    pull the trans and dp's and you should be able to get it done that way. i tried it that way at my shop and stripped out 2 turbo bolts and ended up pulling the motor to do the install.
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Tried it the first round and the turbo bolt broke on me. Will be pulling the motor out soon.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    Quote Originally Posted by ThirdStrike View Post
    .rollseyes.
    It's every noobs pipedream
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Can I install valves by removing my valve covers?
    l gotta-- l gotta get
    a form from a scientist.
