I got them, the tbb is going to be useless, but everything else is fine.
only "issues" is the lower intercooler hoses were a little bit short, but they still fit fine, other than that they are tigter than stock so you will need to lube them with something like siicone spray or honey goo (something non-petroleum based) to slide them on easier. as well as lubing them i had to remove the headlights to have enough room to work with them. other than that they are fine.
the hardest hose to put on was the one off the drivers side turbo into the charge pipe, i had to remove the shield above the drive shaft and unbolt the charge pipe from the block, etc, took a couple hours due to the tight fit and inability to get a good hold on the hose.
