Results 1 to 6 of 6
    Aug 21 2008
    Long Island
    Help. Any idea? Whistling sound from engine + Check Engine Light
    Before I bring it to the dealer, i'd like to know what i should bring to their attention first in the case they don't find anything...which has happend before with a loud "clank" form the front end a few weeks ago.
    There's a loud whistling noise at idle, sounds like a constant sound of a cricket. Plus, the check engine light came on after i noticed the sound after i parked in the driveway. Does anyone have any idea what that could be?
    Thanks.
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Re: Help. Any idea? Whistling sound from engine + Check Engine Light
    cheack air condition or for a turbo leak
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    get the code scanned at autozone. then look it up.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Three Rings Jay B7's Avatar
    May 08 2008
    2005 S4 Avant Quattro; 2014 Honda Pilot Touring 4WD 2007; GSXR 600; 2019 VW E-Golf
    SF Bay Area
    diverter valve
    Tap, Snap, or Nap!!!
    2005 B6 S4 Avant; 2007 B7 A4 2.0T Quattro; 2007 GSXR 600;
    Veteran Member Three Rings greg@dubaudi's Avatar
    Feb 05 2005
    2001.5 pearl WB Avant, 2016 SQ5
    Alton Bay, NH
    PCV..... start it and try and pull the oil cap off it its real hard than its the PCV valve
    2001.5 EPL/Tial 770 Pearl WB Avant///2021 SQ7 Nimbus Grey///2021 GMC 3500 Duramax
    Active Member Two Rings OOOOeric's Avatar
    Sep 25 2008
    Ottawa
    Quote Originally Posted by greg@dubaudi View Post
    Greg,
    I have a similar issue, however my engine is just rough and noisy, drives like crap.. I am trying to figure out if my PCV is the problem, I went to the dealer but of course they didn't check it even though I asked, thinking they know better for a change.
    So I tried what you suggested (removing the oil cap while engine was idle running) and sure enough it was under vacuum, I did not remove it completely though (for fear of wearing engine oil in the face hehe) but as I pulled away, engine started wanting to stop...
    So essentially, should the case be under vacuum or not?
    Thanks
    Eric
