Originally Posted by
actlsub9
Yes ET39 is getting better. But aren't you rubbing the outside fender sometimes? So if you have 1/4inch on the inside and no room on the outside, then a even higher offset would be better. Which means greater then ET40.
Well if with et39 I have only 1/4" between the wheel and the shock, with a higher offset (et40, 43, ...) there is going to be even less clearance. If I went to a 9" front ET39, 1/4" would go each direction from the center of my current 8.5" wheel. That would put the wheel on the shock. So if you wanted to run a 9" wheel up front it would need to be a lower offset than et39, get what Im saying?
