Results 1 to 11 of 11
    Senior Member Three Rings TverRus69's Avatar
    Sep 02 2008
    98.5 2.8 A4 QM
    NYC, Penn State, Tver Russia
    Black Smoke and Death... [=(]
    The car started acting up a few days ago. It wouldn't start unless i gave it gas and then had to keep pressing the gas for 20 seconds or so until its able to maintain ~800rpm (rough idle tho) by itself. When i give it gas it would stagger and try to die around 2000 rpm, but would sound decent above 2500. However, the first time i brought it up to 5k, there was a pop and a cloud of black smoke. There was less smoke after that. There is also water and oil (black but thin) in the exhaust (on the tips). I was convinced it was the MAF, changed it, but it didn't help. I'm waiting on a VAG cable to see what the codes are. Does anyone have any other ideas so far?
    Also if i give it gas and rev it up to 6k, then let go off the gas, the car dies. If i keep it up as 1500, then let go off the gas it levels off and idles at 800
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    Re: Black Smoke and Death... [=(]
    o0o0oo that doesnt sound good.. at first i was gonna say fuel pump but after i read on, im not so sure
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    kind of sounds like a clogged cat to me
    have you been noticing decreased performance up to this point ?
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    all the black is unburt fuel... so you're either dumping too much in there or somethings not firing right.
    Veteran Member Three Rings calvin1.8t's Avatar
    Oct 21 2008
    Mk3 vr6
    New Jersey
    its probably your fuel system or cat. check and see if your fuel injectors are clogged if not check the spark plug wires.
    Sep 02 2008
    98.5 2.8 A4 QM
    I've had an on and off CEL for a catalytic converter (trying to find one right now) but i never thought it'd lead to this. Could the staggering and lag be caused by a failed o2 sensor in that cat?
    Also "all the black is unburt fuel... so you're either dumping too much in there or somethings not firing right."... what am i dumping too much of?
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    have you gone over all your vac lines ect..? you should. He meant its dumping to much fuel (running rich). But for that to happen someone would either of had to mess with your fueling or have a big leak somewhere.. VAG the car, see if it is mis-firing or anything and what codes come up. That is your best bet besides checking all your lines. Also, you sure it is oil and water? It is probably just unburnt fuel which will create like black soot at the tips..
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    The cat burns excess fuel. A cat not burning it would cause soot. A cat can choke up the motor and cause drivability problems. A bank 1 or 2 senor 2 oxygen sensor will not cause soot or drivability concerns. What is the code?
    Sep 02 2008
    98.5 2.8 A4 QM
    Well it doesn't smell at all which is why i originally ruled out the unburnt fuel. Its black and really thin - i was thinking burnt oil with condensation. Now that i think about it, it could be the remains of unburnt fuel... and seeing how one of the cats is bad its a very big possibility. I'm getting the codes tomorow or thurs, and see if there's anything besides the catalytic converter. A clogged cat can really be responsible for all of this?
    Dec 20 2007
    iowa
    Yes. Go wrap a rope around your kneck and see how well you can breath that's what can happen to the motor.
    Established Member Two Rings Dr.Coxx's Avatar
    Aug 23 2008
    B5 A4 1.8T
    Jacksonville FL
    Quote Originally Posted by TverRus69 View Post
    Yes it can. There’s a honey comb like filter in the cat. When it starts to wither it clogs up the exhaust. Then (if you have a turbo) it will back everything into the turbo and then the turbo will back up the motor. This will cause the motor to run bad and or miss fire. If nothing can get out the exhaust then soon your turbo will heat up like a lava lamp. The black stuff is lil bits of the filter and condensation. Its most likely the cat.
