Hey guys, i lowered my car about a year ago; anyways never got it aligned because i figured i would run the tires on my HP's into the ground. Anyways my TRE's just went. However i also need a upper right dog bone. Anyways if i replace the TRE first then get it aligned because i need it to be aligned real bad after my wheel bearing; would i have to get a second alignment after i do the upper DB if i do it real carefully?
-If i remember correctly last time i did a control arm rebuild on my buddys i wouldn't have to touch anything that would mess up the alignment when i put on the DB
