Results 1 to 7 of 7
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    What should my O2 sensor voltages be at WOT?
    ok.. on the edyjun s4 site under Lemmiwinks Tuning you come to a part where it says:
    "WOT - tune for O2 v's of 0.85-0.87, (0.875 if you are using 91 octane) which equates to about 11.3-8 AFR.
    If your O2 v's are in the 0.88-0.9 you need to PULL Primary.
    If your O2 v's are in the 0.78-0.8 you need to ADD Primary."
    I thought stoich was 14.7. Here its saying to tune for 11.3-11.8?????
    Im confused, please someone enlighten me, lol.
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: What should my O2 sensor voltages be at WOT?
    That's WOT AFR, 14.7 is only maintained when cruising or idle.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    11.3-11.8 right at WOT, you need to compensate for boost with fuel, if your a/f was 14.7 @ wot you'd def blow your motor.
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Feb 22 2007
    Earth
    I did a WOT run in 3rd gear 2000rpm to 7000 and I got the following voltages. Should I consider doing anything with the primary fuel trim?:
    ProDiag Log: 10/21/08 7:30 pm
    Time (s);O2 Bank 1, 1 (V);O2 Bank 1, 2 (V);O2 Bank 2, 1 (V);O2 Bank 2, 2 (V)
    2.03;0.775;0.715;0.800;0.740
    2.43;0.790;0.765;0.820;0.785
    2.84;0.790;0.780;0.795;0.795
    3.24;0.810;0.800;0.810;0.810
    3.64;0.810;0.815;0.800;0.825
    4.04;0.810;0.815;0.810;0.825
    4.44;0.810;0.825;0.820;0.830
    4.85;0.825;0.840;0.825;0.840
    5.25;0.830;0.840;0.835;0.845
    5.65;0.830;0.845;0.845;0.845
    6.05;0.850;0.855;0.845;0.855
    6.46;0.840;0.850;0.850;0.855
    6.88;0.860;0.860;0.860;0.860
    7.31;0.865;0.875;0.875;0.880
    7.75;0.870;0.875;0.885;0.880
    8.19;0.860;0.870;0.875;0.880
    8.65;0.865;0.870;0.880;0.875
    9.11;0.875;0.880;0.895;0.885
    9.58;0.885;0.880;0.895;0.885
    10.06;0.880;0.880;0.890;0.885
    10.55;0.870;0.875;0.885;0.875
    11.04;0.870;0.865;0.885;0.870
    11.55;0.875;0.875;0.890;0.880
    12.05;0.885;0.880;0.895;0.880
    Feb 22 2007
    Earth
    also, how many volts is an AFR of 14.7?
    Oct 03 2005
    Not really sure, what are you trying to do? If your trying to tune your car you can make small changes and be safe but if your looking to make some good tweaks for race gas or what ever, a wide band is a good idea to tune with and for safety when your not logging.
    Get a wide band, get some q16 lean your shit way out turn up the boost and timing and hold on.
    Edit: don't actually just start playing with timing/fuel settings if you don't know what your doing.
    Feb 22 2007
    Earth
    I was just wondering what a 14.7AFR would translate in O2 voltage. Mainly cause I have some missfires at idle and I wanna check if my AFR at idle is ok
