Results 1 to 2 of 2
    Senior Member Two Rings intonation's Avatar
    Apr 09 2008
    Lawrence, KS
    Advice Needed: Disable E-Brake Warning?
    My parking brake warning light and chime is erroneously coming on. The car coasts fine and I am certain it is a sensor / electronic issue. Problem is, the dealer is booked until next month and the chime is driving me crazy (beeps every 5 minutes) Question is - is there any known method to disable the warning chime? Fuses, Vag-Com, going under the car to pull a sensor cable?
    It is like Chinese water torture to drive for an extended period like this
    Thanks in advance for suggestions!
    Apr 09 2008
    Lawrence, KS
    Re: Advice Needed: Disable E-Brake Warning?
    Maybe another solution is pulling the plug on the chime? If only I knew where it was...
