Results 1 to 21 of 21
    Veteran Member Four Rings norcatalyst126's Avatar
    Galt, CA
    I think I want to buy an Eclipse
    I'm looking for a mid 90's to late 90's GST or GSX. Anyone have any pointers while looking? Are parts expensive? Easy to work on? Electrical problems? Clutch/Drivetrain problems?
    I have found some built ones, but not sure if I want to go that route. Is their AWD system worth it? I have a 4x4 truck, so I won't really need it.
    Any help would be greatly appreciated!
    need rotors?...adam's rotors
    Mar 18 2007
    Boston, MA
    Re: I think I want to buy an Eclipse
    Quote Originally Posted by norcatalyst126 View Post
    Since I have primarily built DSM's all my life... I'll give you some pointers, PM me if you want more info.
    Go for a 91-94 GSX. Yes, the AWD is worth it, to me it works better than the Audi's.. Yeah yeah.. you know why? It's because for some reason when I get stuck in the snow, it seems to work better for me, where the 2 B5 A4's I get seem to have a tendency to let the rear tires spin and the fronts dont' move much. So anyways, go for the AWD, you'll definitely love it. It's too easy to make power from these cars, and the FWD spinning sucks.
    Tranny's are junk if they are notchy, so if it still shifts good, then you should be fine. Otherwise, if it has been modified well, then I wouldn't worry too much about buying built ones.
    Parts, they are certainly cheaper to buy than audi's, but I wouldn't day DIRT cheap. Easy enough to find, and certainly easy to work on the cars in my opinion. Never any electrical issues... so you're golden there.
    95-99 cars are a little "prettier" but are more prone to "crankwalk" problems and come with a weaker stock turbo. Also are more prone to rust in the hatch and strut towers (if you get a bad one, seeing as you're in CA you most likely are good either way).
    Have fun, it'll certainly beat the pants off most Audi's once done up right.... but it's still an 18 year old car, and wasn't mean to be a luxury cruiser... fast as dirt though :)
    03 Evolution 8
    98.5 A4 1.8T
    99 A6 2.8
    Registered Member Two Rings
    Aug 18 2008
    Wrong Island
    whyyy is the reason,,,,,,, mitsubishi is the worst car u can buy bro
    Galt, CA
    Rice.....Thanks for all the info!!!!
    1FAST.....I want a cheap, fuel efficient, turbo car.....(I'm sure there are other alternatives, but I like Mitsu's....I had 2 different Lancers in the past)
    Veteran Member Four Rings pOrKcHoP07's Avatar
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    Quote Originally Posted by 1FASTB6S4 View Post
    You are ignorant.
    2003 Audi A4 1.8T Quattro
    AKA: masterforu2nv
    Current Mods:
    Debadge. 3000k DDM Tuning HID Fogs. 5000k DDM Tuning HID Kit. AWE Exhaust. Window/Fog Vag Mod. VMAXX Coilovers. Enkei Raijins. Adam Rotors. Hawk HPS Pads. SS Brake Lines. RAI Testpipe. Racetec FMIC. JHM SS. Motoza Stage 1 Chip.Evolution Racewerks TIP.
    Veteran Member Four Rings CONTROL TWO's Avatar
    Oct 01 2006
    Cayman S
    SJ
    just no rice please justin.. they can be fast without being rice
    -Grant
    ig: g_strachan
    Registered Member Four Rings cerfus's Avatar
    Oct 16 2007
    Germans
    Scottsdale
    yeah Evo 9's are real pieces ...
    ///Mcars
    looking for a sileighty..
    E39 M5 DD full Hamann exhaust h-back/ Hamann CF splitter/ Hamann C Diffuser/K&N intakes/ecu tune more to come.
    Keep your eyes peeled DG, CRFS coming your way!
    Senior Member Three Rings lonestar22's Avatar
    Aug 19 2008
    DFW
    you obviously have no idea what you are talking about
    SGM 330i 6MT/RD PLATE LIGHTS/RES DELETE
    STAGE 1 B5 S4, CAN YOU SAY SLAMMED?
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    You are one dumb #(@!
    Aug 17 2008
    Just make sure that you have another car to drive around when you are always working on keeping the car on the road. I have had MANY friends that went DSM and they all had low miles because they were always broken. Replacing a trans was like routine maintenance for these cars, crankwalk issues, it was always something. When they actually run though look out cause they are FAST!
    Mar 18 2007
    Boston, MA
    Hehe that's funny..
    Yes, it all depends on your luck and your mechanical skill.
    I have never had a DSM break down on me where I didn't either cause it or ignore something I should have fixed... and almost all those times I fixed it up enough so I could drive off.
    Just like any car, it's OLD, so if you don't replace everything, then eventually things are just going to break. I sit around doing maintenance and notice things myself and replace them.. ie I see some rubber looking dry, I replace a bunch of hoses.... simple preventative maintenance...
    Just like many people warned me the Audi would give me problems... so I've had one problem that wasn't fixed easily.. the rest, again I knew it was failing so I replaced parts.
    03 Evolution 8
    98.5 A4 1.8T
    99 A6 2.8
    Active Member Four Rings
    Dec 11 2006
    Boston
    4g63
    mmmmm...
    Veteran Member Four Rings FITZ TITS's Avatar
    Phila
    whyyy is the question,,,,,,, mitsubishi is the worst car u can buy bro
    Fixed
    Aug 06 2008
    Canadia
    if chevrolet turbod a cavalier, it would be just like one of those old jalopies.
    I don't know about you, but i make it a point that my next car is better than the last one.
    Veteran Member Four Rings TheBlueMartin's Avatar
    Jan 06 2005
    2006 A6 3.2, 2009 Q7 4.2 Prestige, 2014 Regal GS M/T
    Ann Arbor, MI
    I have a 91 GST, got it for $900 a few years back. It has to be one of the most fun cars Ive ever driven (and Ive driven a LOT, including the new ZR1). Parts are cheap, engine building tricks are easy (remove balance shaft pronto), and the looks on the faces of all the people who get smoked are priceless.
    The AWD cars have more transfer case issues than I care to deal with, but thats just me. LSD rear is a must if your going AWD route.
    If you really knew what you were doing and shopped around, you could get a 10 sec DSM for less than $5k...
    A friend of mine just ran a 5.77 in the 1/8 with his.
    http://upload.streetfire.net/video/J...the_192899.htm
    "Mastering others is strength, mastering yourself makes you fearless" Lao Tzu
    2006 A6 3.2 Avant- Black.
    2009 Q7 4.2 Prestige - Lava.
    Senior Member Two Rings votblindub's Avatar
    Feb 21 2007
    ballston lake, ny
    DSM's are finnicky critters. they run okay enough when u just drive them. u start doing something to em like getting hard on them a bit and they fight you and get back at you.
    Nov 19 2005
    Pair of (. )( .)
    please don't tell us that Audi is best car to buy......
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Oct 22 2008
    "totalled" 98 chevy tahoe
    soCal
    its a techno slut car
    Senior Member Three Rings golovemd's Avatar
    Apr 12 2008
    2002 Audi A6 2.7t 6spd
    Connecticut
    I had a 91 Talon TSi AWD. I loved the look, and it was definitely a fun car to drive. It was weird, sitting in the driver's seat gave me the feeling of it being a bigger car. With that said, the second I fixed one thing, something else broke. I really wanted to like the car, and really wanted to keep it and fix it, but it just got to be too much. It was always broken. I finally just decided not to put any more money into it and sold it. I am not sure if I would trust one again, but if you know how to do the work yourself, and don't mind putting in some wrench time yourself, you'll love it. It's an incredibly fun car to drive.
    Jun 19 2008
    florida
    I loved my eclipse. and i agree you will have tons of fun. but i agree i had tons of problems.. it was because i just didn't keep maintenance up on the car... between the two i owned i went through 3 transmissions, and countless belts, i don't want to think back to those days of every 5k replacing a belt(high revving cams vs proper tension settings with a bad pulley). but if i were you i would do tons of research to know where to start and see if you have the time. if you do take pics and keep us updated
    01 a4 1.8tqm, apr tip, custom intake, labree hfc, custom 3" back, apr chip, greddy oil ic, eibach pro street coilovers, GodSpeed FMIC, gauges to monitor, and a loud stereo so i dont hear any squeaks or problems plus weight to help handling lol
    Veteran Member Four Rings fusionx's Avatar
    May 17 2008
    07 A3 2.0T
    Socal / Boston
    eclipse...
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
