Results 1 to 7 of 7
    Mar 21 2008
    Try this again?? Tranny Problems Some ideas Plz
    Ok so A couple months ago i posted that i was having trouble getting into 1st gear ( i could only get in while car was rolling) and i would have to push it in hard. What happend was i grinded 4th gear and after that thats when it all happend. I Drove it like that for about a week saving money to go get it looked at... by the end of the week it had bascially "fixed itself" and was going into first and second like nothign ever happend.... Yesterday i raced my friend from a first gear roll ... Grinded 2nd now It happend all over again.. My friend who works at audi suggested changing the clutch and Throwout bearing?? Idk if that makes any sense thow...
    When it dsoent go into first and second the Shiftlinkage feels reallky wierd like i cant move it to the left and to the rigth while in nuetral but it has fixed this problem itself TWICE already.. i would really like to get some insight on this
    Mar 21 2008
    Re: Try this again?? Tranny Problems Some ideas Plz
    Quote Originally Posted by looseboost View Post
    Bumppppppp
    Jan 17 2008
    louisville
    first and second gear shift collr is bad. these are the EXACT symptoms my car had. im in the iddle of replacing mytranny now. It has not been fun or cheap. i promise you 100% your tranny neds to be replaced or built. Mine seemed to fix itself too and finally one day it wouldnt go bck. it would seem notchy in nutral after going in first or second, anfd the problem initally started after grinding gears. now tht th tranny is out, i have confirmed that this was the issue. good luck, and I hope you have cash
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Jhm kit time
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Mar 21 2008
    im thinkin of taking the ez way out of this situation
    it involves A razor and my throat
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    man... why are northerners always so depressed? It's not like the car cheated on you or anything... I watched a serial killer special on TV and they were all from the north...
    anyway... get some poon and then have a few beers. next, spend $2k (or so depending on if you want more upgrades or not) and get you a JHM rebuild kit, a bad ass new clutch, and resurface your flywheel. Clear 2 or 3 days out of your schedule and rebuild it all... then you'll have piece of mind and a sick setup. Nothing to worry about.
    Mar 21 2008
    is buying diffrent gears a little over kill??
