    Active Member Two Rings Au6i's Avatar
    Oct 17 2008
    More shoes.
    Flawrrrda
    Cruise control crapout?
    For the past 2 weeks, Mine hasn't worked. I tried resetting it, and did the whole "hold tab, push pedal, cruise" shpiel.. I got it to work once the other day, but it only lasted 3 minutes before it turned off.
    Is it mechanical, or electrical? Any help in setting this right would be greatly appreciated.
    Sep 15 2008
    C5 A6 - 1998 - 2.8L
    DC
    Re: Cruise control crapout?
    if it turns off, that sounds like a cruise vacuum leak to me.
    Oct 17 2008
    More shoes.
    Flawrrrda
    Thanks. I'll be looking into that shortly.
    Sep 05 2008
    St Louis, MO
    There seems to be many things which cause the cruise control to fail.
    http://www.audiforums.com/forum/show...=112008&page=2
    http://forums.audiworld.com/a4/msgs/1996882.phtml
    I hope this will help.
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    check fuse? or like above, vac lines
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
