Results 1 to 28 of 28
    Veteran Member Three Rings Robb12's Avatar
    Aug 04 2008
    Orange County
    Thinking of swiss cheesing....
    I came upon the "swiss cheese" mod and I'm just curious if anyone has had any problems, I've searched around and it seems ok. I live in Utah and we're about to get a ton of snow so I might apply mesh to make myself feel better about water getting into the airbox. Anyway, where is the best place to drill the holes? Some have done it on the bottom into the wheel well and some in the front by the headlights...pros and cons? TIA
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Thinking of swiss cheesing....
    screw swiss cheese, all it does is whistle. Pull out your lower airbox and gut it, meaning cut out all the ribbs in there. Get a hole saw and drill a 3" hole in the front, lower portion. Grab some drier ducting and run a 3" flex tube from the lower air dam area (behind the passenger fog light) up into the airbox hole.
    CAI's are weaksauce, homebrew FTW.
    If you still have your SAI pump that may be an issue... my bad.
    Veteran Member Three Rings oldblu's Avatar
    Jan 01 2008
    Budd Lake, NJ
    Quote Originally Posted by djwimbo View Post
    Dude. Please Elaborate. Can water get in if I do that?
    --Silver 2000 A4 2.8L V6 Quattro
    S4 Bumper. Borbet Type LS Wheels. M3 Replica Spoiler
    Blue! How come there's no ice
    in my lemonade?
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    please do elaborate..diy..pics?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by AudiXS4X01 View Post
    Pics would require some disassembly and it's cold, dark and rainy outside.
    Next time you're dinking around under the hood of your car, look infront of the airbox, behind the headlight. You can see straight down to the A/C accumulator and for facelift cars the SAI pump.
    Basically all you do is run a "pick up" down there. You can choose to block off the factory one off the grille, or leave it open. The reason you use the drier ducting is b/c it's flexible, and cheap. Maintaining the 3" diameter from the airbox to where ever you make it end is near impossible w/o removing the A/C and if optioned the SAI pump.
    EDIT: Leaving the factory intake off the grill area would help prevent water getting into your intake. If the lower is blocked from water, the stock one would have the least resistance for air to travel and will let air through easily.
    Aug 04 2008
    Orange County
    so thats a "no" on the choice of swiss cheese..?
    Jan 01 2008
    Budd Lake, NJ
    Do what djwimbo said and take pics+DIY write up so we can do it too. (Please)
    in my lemonade?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Robb12 View Post
    Not worth the effort, I'd go on a diet first.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    swiss cheez it:
    Save your time. It does nothing to improve performance. Don't fix what ain't broke.
    duct it:
    Has the potential for gains but the airbox really isn't enough of a restriction to worry about.
    There are four pictures of this mod in my picture poster. The hose was corrugated on the outside but smooth inside. I ran it this way for years before replacing the box with a stock one. I didn't notice any difference downgrading to a stock box.
    Jim
    I Do Werk.
    Jan 01 2008
    Budd Lake, NJ
    Quote Originally Posted by onemoremile View Post
    Whoa!! "Don't fix what ain't broke" in all its forms is definitely copy-written by me lol
    See
    ...Yeah i'm just kidding
    in my lemonade?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I guess I can't say exactly if the butt dyno approved of the airbox mod or not. I did the testpipe, downpipe, gutted air box and DV at the same time. I don't even think the chip had fully learned it's parameters yet, that or the temporarily open downpipe was that big of an improvement.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I did this a LONG time ago on my car, and IMO its not worth it. After doing it I didnt really notice any increase and now I am left with a hacked up fender liner. Everytime it rains I get scared of water (although I dont think its going to get in there), I am still just paranoid of water getting in there if I drive in a puddle. Save your time and pass on this mod.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings dingguhlbary's Avatar
    Jul 17 2007
    New Jerzzzzzzzzzzzzzzzzzzzzzzz
    if i ever would do this mod, i'd just get an s4 fender liner. they come with vents and stuff.
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by dingguhlbary View Post
    X2, I think Im just gonna go order or buy a S4 liner
    My 5-Speed Swap DIY
    - B6 USP
    Registered Member Two Rings
    Oct 13 2008
    98' A4 | 98' GSX
    Texas
    X3, I got one for $25 on ebay.
    Mar 09 2004
    nw michigan.
    Still pointless and potentially dangerous.
    Jim
    I Do Werk.
    Veteran Member Four Rings audiFUEGO's Avatar
    Jul 17 2007
    2001.5 A4 1.8t QM
    Boca Raton, FL
    I had a complete evoms cai on my car with a true heatshield vented with the stock snorkel... but with my 3" maf it made my car idle horrible and run rich as hell. So I put the stock box back in and problem solved. The only difference in power is maybe a TINY bit of throttle lag compared to a cone filter... so basically, the airbox can move air... unmodified.
    Senior Member Three Rings Insomniac's Avatar
    Jun 03 2008
    Hershey
    you know.. there's already a hole in the air box. For water to get OUT if it gets in. Soo more holes mean more water in and more drainage out and more whistle and no hp gain. Nice.
    free earl
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    There is a big spring loaded flap on the bottom you can take off... makes your intake louder, and gets a little more air... plus its totally reversible.
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    Anyone know what the above mentioned flap is for?
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by 4A Play View Post
    Water?
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Ya I've seen him mention that in a few posts.
    It has to be for something right....hmm
    ~Brian
    1998.5 A4 2.8QT
    Aug 13 2008
    Indiana
    I was told its there in case your pre filter screen gets clogged. That would open and let air in but idk. I took the flap out noticed a tiny bit of noise nothing worth while. I have thought of doing further cutting just to unlock some of that engine growl but idk.
    -Nic
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    If you want the sound, just do a cone filter of the MAF.
    Then, if you decide you want to switch back.... you wouldn't have completely destroyed your airbox by drilling holes in it. The filter will be cheaper than a new airbox.
    {99.5 Avant}
    Aug 24 2005
    1999.5 AUDI A4/T/Q/M
    Chicago, IL
    I been running swiss mod for 3 years. It's ok with me
    B5 1996 2.8L A4/Manual (SOLD)
    B5 1999.5 1.8T A4/Manual (SOLD)
    Acura TSX 2004/Navi Package (SOLD)
    SOLD 2.0T,(2009)MKV,TSI,6-Speed Manual
    *CURRENT*MK6/JETTA/6-Speed Manual
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Quote Originally Posted by dj spiel View Post
    Three years for me too now with no, no problems.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Apr 22 2007
    Riverbank, Ca
    I basically cut my whole bottom of my box out. Theres just as much risk running that as a cone filter...
    Swiss cheeze all you want. But you might as well just get a hack saw and go some serious cutting. Just leave the mounting points there. and bam you instantly have an "intake"
    Dec 01 2006
    Santa Cruz, CA
    Quote Originally Posted by andyrew View Post
    Thats exactly what i did and it works great. no problems and a little louder.
