Results 1 to 10 of 10
    Oct 28 2007
    j-ville
    Please HELP. output speed sensor
    2004 audi a4 FWD
    Check engine light is on and code reads bad output speed sensor (P7022 i think it was, not positive). I called the dealer and they say they wont simply replace it, they have to go through diognostics and all. then a few hours of replacing the part. So basically they are gonna rape me. So anyone else have this prob and how did they go about it. what should i do
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    Re: Please HELP. output speed sensor
    its a very easy fix if only the sensor is bad... if you feel like doing it yourself just crawl under your car, the sensor is located on the side of the trans near the rear. if you dont want to do it, buy the part at the dealer and have an independent shop install the sensor for you. and i believe you mean P0722 not p7022.
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Oct 28 2007
    j-ville
    Ok cool yeh i think you had the right code. I was told there were two sensors, primary and secondary is this true? Also is there anything else that needs to be done when installing the part or simply just swap them out. lastly does anyone have a diagram of tranny and sensor?
    Oct 28 2007
    j-ville
    bump
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    The sensor is held in by one bolt iirc. It's just the one sensor. It just connects to the panel on the battery firewall. Just get the belly pan off and look at the back of the engine oil pan near where it meets the transmission on the drivers side in front of the battery firewall.
    Oct 28 2007
    j-ville
    im hearing that the tranny control moduel has to be replaced when you have a bad speed sensor?
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    This happened to me last year. It's a $100 part and easy swap out. I don't have a picture of where it's located, because I have a quattro, but it's a simple fix requiring nothing extra....or at least i think
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    If you are refering to the sensor that reads the crank then all those codes are not right if this is the part though.
    click here
    Edit: no idea why that link is bringing you to the wrong section of the site, but go under Maintenance and Repair then down to Engine Speed Sensor.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Veteran Member Three Rings passatkid's Avatar
    Sep 19 2006
    ND
    I Believe the on the transmission is for the speed and that is the one he is referring too.
    Oct 28 2007
    j-ville
    yes im referring to the sensor on the trany, not the engine speed sensor. And suposedly only the cvt trannys need the TCM to be replaced
