Results 1 to 6 of 6
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    rear caliper removal
    I know there are a few threads on this.... just have a question.
    I was able to do one part of the caliper removal, cept I could not get the bolts out from the back of the Rotor.
    Very hard, and not much space to work. I was using an allen key, but I could not get enough leverage with all my might.
    What tool do you guys use to remove those large bolts behind the Rotor?
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Feb 17 2004
    Liberty Hill, TX
    Re: rear caliper removal
    sawed-off hex socket w/ratchet works best
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Buncha motorcycles
    Memphis, TN
    i used an allen key on one side with a pipe for an extension but the other side i could not get the bolt turned far enough to get the allen key back on it. i tried a allen socket next but there wasnt enough room for the rachet head so i used the allen socket and put a small 1/4 wrench i think on the allen part of the socket then put it on the bolt and turned it very slowly...
    APR Stage 2/AWE Intake
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Go buy a stubby allen socket set. Or just by the 8mm stubby allen socet and use a ratchet with at least a 12" handle or throw a pipe around the ratchet yu have. Unless your car is new and never seen winter, you are going to have a very tough time with an allen key. The bolt is very stubborn so that's why I recommend a long handle ratchet so you have more leverage and a stubby socket because the long will may warp/bend/break or strip the bolt.
    Apr 02 2007
    Thanks for the replies guys!!!
    Taylor A. Maneri
    tamaneri (AIM)
    Oct 19 2005
    ontario
    you should be able to remove the top one, then if you are removing the rotor just tap the carrier back an inch or so and the rotor will be able to come off.
