Results 1 to 8 of 8
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Coolant Temp Sensor Location
    Where is the coolant temp sensor located on 4.2L?
    I followed the lines from the coolant tank but didn't see it anywhere below.
    If there isn't DIY out there I can take pics as I go along. I know how to change it just need to know where it is on this engine. Thanks.
    Mar 24 2008
    khgkhg
    Re: Coolant Temp Sensor Location
    Couldn't find any info for 4.2L but 3.0L layout looks about the same so this should be correct. Maybe someone else would need this as well.
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Quote Originally Posted by 40valve View Post
    Did yours go bad? (obviously it did, but what was the car doing that told you it was bad?)
    Mar 24 2008
    khgkhg
    It's not bad yet but it is throwing a code which I don't have on me right now. I'll post it up later.
    Mar 24 2008
    khgkhg
    19497 - Powertrain Databus: Implausible Engine Temp. Message from Inst. Panel
    P3041 - 004 - No Signal/Communication - Intermittent
    From my research it looks like bad sensor can do this. I've looked in car service history and that was never replaced before so it's a good place to start. Could be just a bad connection somewhere too. Should already have the green one but at $20 it's worth it.
    Registered Member Two Rings hackers4's Avatar
    Jun 12 2007
    Miami, Fl
    I replaced mine and it was a pain. Takes a lot of patience.
    2005 Audi S4
    MTM Fullback Exhaust
    ASR Engineering Test Pipes
    O.CT Chip
    EVOMS Intake
    H&R CO
    H&R Sway Bars
    Stasis Center Differential
    Stratmosphere SS
    BBS RS-GTs
    Jun 12 2007
    Miami, Fl
    And yes, that is the correct location.
    2005 Audi S4
    O.CT Chip
    EVOMS Intake
    H&R CO
    H&R Sway Bars
    Stratmosphere SS
    BBS RS-GTs
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    That is kinda where it is. The sensor is not located up and down like the pic for refrence. It is located above the trans bell housing more in between the cylinder heads.
    As you can see it is in the upper right hand of the pic. The is taken from under the car with the Dp's removed. you are looking at the back of the motor. You can see the trans in the bottom of the pic.
