Results 1 to 10 of 10
Thread: APR Questions
    Registered Member Two Rings
    Sep 16 2008
    2008 Audi A4 MT6
    Florida
    APR Questions
    Got the car flashed a couple weeks ago and I am starting to notice some strange things. Sometimes when I turn the car on the instrument panel, and climate control is reading the temp in Celsius. If I turn it off and back on it goes back to fahrenheit. Also, I have been noticing a whistling noise every so often. Again...it comes and goes. Should I be concerned. Any suggestions?
    Established Member Two Rings I495 Bandit's Avatar
    Jan 08 2008
    01 St3+VW Jetta/06 A4 S-Line
    NoVA
    Re: APR Questions
    I'm not sure about the climate control but the whistling noise you're probably hearing is the turbo. Remember that with the APR flash you are now running more boost. Its totally normal to hear the turbo whine more with a chip.
    May 20 2004
    More cars
    Never Land Ranch
    Re: APR Questions
    Do you have a boost guage? if not you might want to get one just so you know if your PSI is too low....
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Senior Member Two Rings ABL2point0T's Avatar
    Nov 09 2006
    Charlotte, NC
    Re: APR Questions
    Are you using both sets of keys? One key may be set to Centigrade and the other to Fahrenheit. You can set both of them up to read either or.
    2006 A4 2.0T Titanium 6 Spd Manual (Sold)
    2008 335i 6 Speed Manual
    PS3 Username: Wolfpack1
    Apr 15 2007
    WNC
    Re: APR Questions
    Almost 100% that the whistling is when you're pushing the car harder...its definitely the turbo. I heard the same thing and took my car to the dealer. No problem
    2013 RS5, 2014 Q7
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    Re: APR Questions
    Quote Originally Posted by ABL2point0T View Post
    lol that happened to me a while back with my S4. I was thinking WTF and chalked it up as typical German electrical gremlins.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Sep 16 2008
    2008 Audi A4 MT6
    Florida
    Re: APR Questions
    Quote Originally Posted by SEXICAN View Post
    I did have a boost gauge installed along with a forge DV. What do you suggest is a "good" PSI? When idle? Driving?
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Re: APR Questions
    Quote Originally Posted by 4rings15 View Post
    When idle you should be around -20hg, should peak around 18hg with the APR chip, and normal driving will vary depending on how fast you're going and how much strain is on the engine. Normal driving I try to keep it at or below 0hg so that my turbo isn't spooling in the interest of saving gas.
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    Re: APR Questions
    I hope you are enjoying your new power!
    In regards to the instrument cluster, I don't think its related to the flash at all. We don't do anything to interface with the instruments. The ecu reports data to it most certainly and we do reflash the ecu but other than the engine data stream coming from the ecu, the instrument cluster is its own independant controller. The issues you are describing sounds like either the key suggestion that another poster made or the cluster is losing its coding somehow temporarily. Sounds like you will need a trip to audi if the issue persists.
    Please let me know if I can assist further.
    Sep 16 2008
    2008 Audi A4 MT6
    Florida
    Re: APR Questions
    Thanks for all the help & suggestions. I appreciate it!
