Results 1 to 31 of 31
    Registered Member Three Rings ILikeBigBrakes's Avatar
    Sep 27 2008
    2002 Audi A4 1.8 Q&A
    Orlando, FL
    Transmission Flush Question - $525+ from dealership?
    I just called the local dealership and $525 plus tax for a flush and filter? I mean I know its Audi but seriously that seems a little high. I am almost inclined to try it myself but I don't want to anything wrong. Is this about right for what people are paying to have this done or is there anyone in Orlando or surrounding that can do this for alot less than that?
    Sep 13 2008
    Western Chicago Burbs
    Re: Transmission Flush Question - $525+ from dealership?
    Way too high. Find a local transmission shop. I had mine done by a reputable shop where i live for 250.00. if you are going to do it yourself just use a good fluid approved for VW/Audi.
    Jul 12 2008
    audi b6 avant
    Fredericton NB Canada
    i hope it for a tiptronic !
    NO, I'm not drunk or stupid. i'm from Canada and my first langage is FRENCH, so don't ask why my english suck so hard !!!!!
    Sep 27 2008
    Orlando, FL
    Did you supply the materials for that price?
    Sep 27 2008
    Orlando, FL
    Quote Originally Posted by rtb98 View Post
    Yes, sounds like it may be easier?
    Sep 13 2008
    i only supplied the filter kit
    Sep 27 2008
    Orlando, FL
    Oh wow ok I was going to get the fluid and filter kit from here:
    http://www.blauparts.com/proddetail....od=F2A1007%2DA
    So maybe I would be looking around 150-200 at a good shop, just been reading that the temp has to be a certain degree and etc.
    Sep 13 2008
    good kit. thats the oem fluid i think. i think i would stick with the oem fluid because of how sensitive our transmissions are. mobil 1 or royal purple might cause problems.
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    to the OP, i work in a trans shop.. just let me know and i can ship you out fluid and filter for under 200 and you can do it yourself, the fluid is like $13 a quart but i dont see where they came up with $500. the only thing that sucks is filling the trans through that little plug with a suction/pump gun.
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Feb 06 2008
    it would be about the same price as that kit you posted
    snailspeed.net
    Sep 27 2008
    Orlando, FL
    Def. will I am not good with that kind of stuff or I would do it myself I do my oil and did my diff fluid on my gto I used to have once with help haha. My buddy said he would just do it for 150 so I ill probably get the kit soon and have him do it.
    To the above would your kit come with all of the gaskets and extras the blauparts does?
    Feb 06 2008
    that kit is actually a pretty good price, at my shop we stock the fluid, filter and gaskets, but i would not be able to include the spare hardware(not sure why its included) or the filler pump (you can get one for $8 at napa). 5 quarts fluid at around $15 each ($75) plus the gasket ($12 i think) and the filter ($40 i think) would come out to about $120 plus shipping... honestly i would just buy the kit, its exactly what i would sell you at about the same price and they include more....
    snailspeed.net
    Sep 27 2008
    Orlando, FL
    Ok... well hey what turbo kits you got coming in might want to upgrade my gtrs soon
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    BigBrakes, how many miles do you have on your car?
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Sep 27 2008
    Orlando, FL
    81k and I am not sure if it has been changed prior but I do know that when it downshifts to first from second or goes into park its jerky. So either it needs a flush or has work done to it? Not really sure.
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    that is NORMAL price to flush your transmission in regular Audi Dealerships.
    welcome to call in any other Audi dealership for trans flush price quote.
    I did it in local independent shop for less than $400.
    Feb 06 2008
    we would do it at my shop for about $225-$250... $120 for parts and about an hour and a half labor even though it dosnt take a whole hour and a half.... but we have to cover our ass incase something dosnt go right.
    snailspeed.net
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Mmmm sounds kinda high. But if its an auto transmission, then I guess it may hit that high. I remember when I did my manual transmission, I bought 4qts? for the transmission and a few more on the rears.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Sep 27 2008
    Orlando, FL
    would there be any modifications to the trans that could be causing it to only buck into drive and downshift into first? I mean it doesnt do it in reverse or any other gear.
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    I'm in Orlando and got quoted $260 from ETA Tuning in Sanford.
    GO KNIGHTS!
    Feb 06 2008
    Quote Originally Posted by ILikeBigBrakes View Post
    it could be a solenoid problem... any check engine lights? since you only get it into drive and downshift to first coming to a stop it sounds like your TCC (torque converter clutch) is sticking on..
    snailspeed.net
    Sep 27 2008
    Orlando, FL
    Yes but my vag-com stuff isnt here so I cant read into the problem
    Feb 06 2008
    Quote Originally Posted by sloweryucf View Post
    thats a pretty normal price for our cars... the price of our auto tranny fluid is the killer, for instance a gm with a 4t60e trans is only about $90 for fluid and filter change, but the dextron fluid is only like $2.50 a quart where our fluid is more like $15-$20 a quart depending on where you buy it and the filter is almost $40 where the gm filter is like $6.50 from napa
    snailspeed.net
    Feb 06 2008
    swing by an advance auto or a carquest and get scanned for free then tell me the codes that are trans related and i can tell you what needs to be done to fix your issue.
    snailspeed.net
    Sep 27 2008
    Orlando, FL
    ok ill do that tommorow
    Feb 06 2008
    PM me the codes if you want so i dont forget to check your thread...
    snailspeed.net
    Sep 27 2008
    Orlando, FL
    Ok will do! I get out at like 530ish so I will go after and see what codes we got that might explain the harshness. Still getting it flushed either way.
    THANK YOU!!!
    Feb 06 2008
    no problem, i always like to help out when i can
    snailspeed.net
    Sep 27 2008
    Orlando, FL
    Sending codes now - nothing trans related from what advance told me
    Established Member Two Rings A4donkey's Avatar
    Sep 24 2005
    Anywhere
    where is the tranny drain and fill plug location (any pics)?
    Sep 27 2008
    Orlando, FL
    Not really sure have not been in there yet..... what I am wondering is what does the dealership do that another transmission place wouldnt that makes it more expensive? I understand in general the dealership is more expensive but compared to other prices locally 2-300 more expensive?
