Results 1 to 8 of 8
    Registered Member Two Rings MidwestA4's Avatar
    Oct 04 2007
    The Palm, Michigan
    Low Profile Front Lower Subframe Mounts
    Does anyone know if a company or private seller makes lower profile FL subframe mounts?
    My car is quite low and the odd structural shape of the mounts scrape on many road surfaces or steep driveway entrances.
    These things are simply thin gauge metal as well. I think it would be a nice little upgrade to do a piece in billet aluminum that has a lower profile.
    I was just wondering if these are already available somewhere before I make something up in solidworks and cut it out on the CNC at work.
    - 98.5 A4 Quattro
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: Low Profile Front Lower Subframe Mounts
    I dont think anything has ben done. How do you grab that without grabbing your oilpan?
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Oct 04 2007
    The Palm, Michigan
    i have a 2.8L the oilpan is tucked up higher than both the subframe and subframe mounts.
    - 98.5 A4 Quattro
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Are you talking about the goofy triangle piece at the rear of the subframe?
    I'm sure you could make a set out of flat stock, that way it wouldn't have that big dimple hanging down.
    .... or raise the car, obviously that shit is REALLY low.
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    they will eventually wear down, and not scrape anymore
    as me how i know haha
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Oct 04 2007
    The Palm, Michigan
    Quote Originally Posted by djwimbo View Post
    Yeah the triangle bracket with the lump in it.
    Pshh.. I'm only at 23" up front. I'll be spending all winter cutting, fabricating and clearancing the wells in order to go lower and fit the Carlssons I've been wanting to jam in there.
    Quote Originally Posted by pacman View Post
    how do you know?!
    I should have the CAD for these finished this week. Then all i need to figure out is which material to go with.
    - 98.5 A4 Quattro
    Nov 06 2006
    garage ornaments
    southeastern pa
    link to picture in my sig
    22" ground to fender
    -Nic
    My Car
    Oct 04 2007
    The Palm, Michigan
    Trust me buddy.. I'm aware of how low your car has been :)
    - 98.5 A4 Quattro
