Results 1 to 13 of 13
    Jan 01 2008
    Long Island NY
    Anyone from APR need an answer!!!
    I dynoe'd 220WHP and 255WTQ Yesterday on a Dyno Jet. Will your APR S3 Turbo Kit for the B7 Tip break the 300WHP mark with Fuel Pump, FMIC, Software, Injectors, Test pipe, Full Exhaust???? I really need an answer because im either going to wait out for yours or go ASP now... I would rather stay with you guys but i have called you and no one seems to be able to give me an answer on this kit. I don't care about crank numbers i want WHP.
    Jan 01 2008
    Long Island NY
    Re: Anyone from APR need an answer!!!
    Bump.
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    i doubt it, maybe 265 270 whp tops... 300whp is already at the limit for the 2.0t motors
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Jan 01 2008
    Long Island NY
    Bump
    Jan 01 2008
    Long Island NY
    Bump.
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    you should also care about cust service
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    Thanks for your interest in our upcoming turbo kits for the B7 A4.
    At this time I cannot comment on the final power gains as they are not released from our engineering department. We have been showing 323 flywheel hp and 338 flywheel trq for the S3 ko4 and 373 flywheel hp and 340 flywheel trq for our Stage 3. These numbers are conservative estimates from preproduction testing. I would think that the release will see similar numbers but I don't think they will be enough of an increase over the 323 to confidently recommend to you that it will make 300whp at this time.
    Jul 11 2005
    Auburn
    Quote Originally Posted by Johnnie View Post
    I care very much!
    Jan 01 2008
    Long Island NY
    Keith what turbo does your Stage III come with? Any numbers on how much?
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Quote Originally Posted by Keith@APR View Post
    The GT kit will be comparable in pricing to our transverse 2.0T Stage 3 and the BW kit should be slightly less expensive than our ED 30/Audi S3 conversion for the transverse.
    there you go, but that was from around waterfest time
    -Kris
    Jul 11 2005
    Auburn
    Quote Originally Posted by Auditude2.0T View Post
    2871r!
    Oct 09 2007
    E46 M3
    PA
    Still had this in my glovebox so I scanned it for you
    -Kris
    Veteran Member Three Rings johntesi's Avatar
    Jan 17 2008
    Evolution X
    Texas
    Pete-
    It seems like you've been setting lots of extravagent benchmarks. Maybe instead of being set on an exact time in the quarter mile time or simply breaking 300 WHP (which something tells me comes from your quarter mile desires), focus on making it a great all-around car. A K04 will preserve drivability with minimal increase in lag. It should get you darn close to 300 whp if it doesn't get you all the way there, but from what I hear and have witnessed on these boards, APR stands behind their stuff and makes quality products. I haven't purchased a single thing from them, so this isn't any kind of miracle testamony. Our cars aren't made for benchmarks. Moreso for refinement, balance, area under the curve, etc. The bigger your turbo gets, the less of all of the above things you have. Just my two cents.
