Results 1 to 6 of 6
Thread: Newbie question
    Senior Member Two Rings AlexsB5S4's Avatar
    Oct 27 2006
    01 S4
    Newbie question
    so i'm doing turbos in my car and i keep reading all these threads on not properly priming the turbos so i was wondering how exactly do you properly prime the turbos? is it done prior to install or after? cause the last thing i need is to blow my new ones. thanks
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    Re: Newbie question
    dont connect the ICM's (ignition control modules) so it wont turn over
    just crank it for about two minutes get the oil/coolant in them then connect the ICMs and start
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Apr 18 2007
    b5 s4 nogaro , 1991 bmw 325is 5spd
    florida,wellington & hollywood
    Re: Newbie question
    or the fuse for the fuel pump either one is good ;)
    cheers
    --daniel
    Established Member Two Rings jaredsogn's Avatar
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Re: Newbie question
    Quote Originally Posted by AMC83189 View Post
    Mind you, don't do it for 2 minutes straight. I usually pull the ECU, crank it over for about 10-15 seconds, and repeat 4-5 times.
    Apr 18 2007
    Re: Newbie question
    lol good footnote there man i also forgot to add that hahah
    Jun 15 2007
    Re: Newbie question
    Quote Originally Posted by jaredsogn View Post
    lol yes definitly dont keep doing it for 2 minutes straight unless u want a new starter.
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
