Page 1 of 4 123 ... LastLast
Results 1 to 40 of 142
Thread: Biggest FMIC
    Oct 29 2005
    10speed
    San Francisco, CA
    Biggest FMIC
    Hey guys, I don't have my car here and I want to make sure this would work. Can anyone take measurements and see what the MAX width and height are that we can fit behind the stock bumper? I dont care if I have to hack the bumper to hell I just want to know what is the absolute largest we can do
    Thanks,
    Clint
    - Clint
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Biggest FMIC
    Just go ER Comp.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    My core alone is 22x11.3x2.5 + 3.5" endtanks on each side and is the absolute widest that fits, I also had to modify the AC condensor lines and completely remove the bumper support. If you are using a 3" core you will need to get a bit narrower and dont go above 12" tall
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Biggest FMIC
    Quote Originally Posted by dirtybrd View Post
    Just go ER Comp.
    I have it already, but Ive realized that its way too small for what I want to do... 660cubic inches is decent, but Evos/STIs are running 1000-1200 cubic inch cores with 30Rs and up... Some even with stock turbos
    - Clint
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Biggest FMIC
    Quote Originally Posted by A4ringedONE8T View Post
    why can't I go more than 12" tall?
    - Clint
    Mar 21 2006
    Lakeland, FL.
    Re: Biggest FMIC
    Shawn, I thought I noticed a change in your condenser, repost a pic.
    I'm back bitches!
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Biggest FMIC
    hmmm yea, Shawn if you could...
    Also, I think Ill be going with the Precision 750 setup
    its
    31.5" L
    10.3" H
    3.5" D
    - Clint
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    its
    31.5" L
    10.3" H
    3.5" D
    Won't fit, I have one here and tried it when I did mine, its way too wide, and thats in the USP front, the stock front is much tighter
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    Its still the same condensor, I just had to modify the lines on each side and move them out of the way, normally they stick out in front of the flat of the condensor
    Mar 21 2006
    Lakeland, FL.
    Re: Biggest FMIC
    That's what I meant, to your condenser.
    I'm back bitches!
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    Because it wont fit
    Heres a pic of mine, its about 3/4" short of hitting the radius that starts to turn in at the top of the bumper
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    I dont have any pics without the core on but you can tell some changes to the condensor here
    Mar 21 2006
    Lakeland, FL.
    Re: Biggest FMIC
    On the drivers side, doesn't the line connect to the frt. bottom of the condenser?
    I'm back bitches!
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Biggest FMIC
    meh, Ill cut the top of my bumper to be honest, I really don't care... I want something thats ~1200 cubic inches in there... can we do 3.5" thick?
    Also, what does the hood allow to clear?
    I might try to do something thats like
    3.5" Thick
    22" long + endtanks
    15" tall
    - Clint
    Mar 21 2006
    Lakeland, FL.
    Re: Biggest FMIC
    You're going to lose some spool by going so big, that's alot of volume to fill.
    I'm back bitches!
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Biggest FMIC
    I'm aware, but I'm going to gain some boost in the long run... Honestly, look at any Evo/STI FMIC kit and see what the dimensions are.... The ER Comp is almost 1/2 the size
    - Clint
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    It usually is attached at the bottom yes, it is not a feed line though, just a thick ass support bracket for the part you see bent back out of the way in that pic. I cut it inorder to push it back like you see
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    Your being dumb, its not needed. My core never ever gets heat soaked, even in the 100 degree heat, retarded humidity, and high boost
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Re: Biggest FMIC
    What do you do for a rebar?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Biggest FMIC
    The ER comp is a 600hp core.
    Going to big is going to have a larger pressure drop which means lower boost not higher, it also means your turbo has to work much harder to fill the core.
    I run a Garrett 800hp core, that is what is used for the GT35r setups and ER offers that core in their Race Series kit for the B5 1.8t, that core is 24x10.3x3.5".
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    Quote Originally Posted by vdubstreets View Post
    Dont have one
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    Also keep in mind the Evo head outflows the 20v head like no ones business, of course it can take added flow over our cars
    Mar 21 2006
    Lakeland, FL.
    Re: Biggest FMIC
    I wish I would have noticed that, I had my IC notched out to fit around that.
    I'm back bitches!
    Feb 20 2007
    ct
    Re: Biggest FMIC
    Dont have one
    worry at all driving w/out one? I haven't had one on the car since I owned it. Everyone pushes me to get one on there.
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    Re: Biggest FMIC
    what is heat soak?
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    Re: Biggest FMIC
    this is true
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    Nope, makes me feel a bit better that the car can stop on a dime though with the Alcon's
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    Quote Originally Posted by PCYC View Post
    what is heat soak?
    When the intercooler has absorbed as much heat from the charge air as possible and it has reached the temp of the surrounding air, meaning there is no more heat transfer from the IC to the passing air
    Mar 21 2006
    Lakeland, FL.
    Re: Biggest FMIC
    what is heat soak?
    When your IC gets hot all the way across and stops cooling the pressized air.
    I'm back bitches!
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    haha I was afraid to cut it as well but luckly Adrian made me do it! lol
    Mar 21 2006
    Lakeland, FL.
    Re: Biggest FMIC
    Knowing that means I can bring mine down more. I still have about 1.25-1.50" before it hits the lower bumper.
    I'm back bitches!
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Biggest FMIC
    its not a huge difference over the AEB
    - Clint
    Jul 07 2004
    socal
    Re: Biggest FMIC
    How many AEB guys you know running 272-280 cams?
    The 510 that was running in my class at the drag event this weekend was running a 290 cam. Lets just say that car made no power at all below 5500 rpm.
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    Uhhh yes, it is
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Biggest FMIC
    Uhhh yes, it is
    where are your sources? A ported AEB will outflow a stock Evo head by a substantial amount
    - Clint
    Feb 17 2005
    Sarasota, FL
    Re: Biggest FMIC
    A PORTED AEB head will outflow a STOCK EVO head ... lol
    Stock for stock the AEB is by far inferior, ported for ported, again the Evo head is better
    And just make your shit run already. Stop comparing your car to others, its not an Evo, it will NEVER make Evo GT35R power no matter what you do ...
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Biggest FMIC
    I wasn't the one who brought up the evo thing... But either way I'm trying... its tough having the car in NJ and me being in MD
    Never say never man...
    What do you think is the thickest core we can run btw?
    - Clint
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Biggest FMIC
    Can't you tow the car to Maryland?
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    Re: Biggest FMIC
    the problem for us is that we dont have a guy like dave buscher who spends his entire life building and tuning dsm's, if we did we could all follow suit and have 800awhp evo's, but we dont have a dave buscher in the audi tuning world so we all try different things and then bash each others thoughts on how to make big power on our motors... plus the evo's engine is based off the 4g63 powerplant that mitsu has been using since the late 80's. the thing is no body exept maybe a handful of tuners were breaking 400whp on that motor even in the mid 90's.. and now we are in 2008 where DSM guys have had about 20 years on that motor and they are finally making nasty ass power... so how about we all try and put our minds together and make some nasty ass power instead of just bashing everyones ideas and not getting anywhere by keeping idea's to ourselves in hopes of one day being able to log onto audizine and say "my shit is better than your shit"
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Biggest FMIC
    Quote Originally Posted by 400HPA4 View Post
    Heres the problem... My friend Paul was supposed to weld up my manifold, come here, and get the turbo setup on and weld my full V-band exhaust up with the wastegate dump and also my new IC piping...
    Well, he hasn't been able to come but I can't wait any longer so now I need to find a place to weld my exhaust up. I could bring the car here and leave it in the street, but I don't know how I would be able to get my exhaust made
    - Clint
