Results 1 to 3 of 3
    Apr 14 2008
    a4 avant
    marlboro
    wastegate problem need quick advice
    can you destroy a wastegate by runing the vac lines wrong?- well what happend the gizzmo was not controlling boost no matter what setting 20lbs half throttle...so i switched the lines to the correct position i believe, out from solenoid to top of wastegate vacuum line and the out from wastegate a tee into the engine line and the line to in on solenoid this line i connected to the middle vac line
    it boosted perfectly and then my wastegate just started to stay open? im lost
    -vrt-
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: wastegate problem need quick advice
    to the best of my knowledge no.
    Then again, I'm an idiot, but it's a quick answer.
    Apr 14 2008
    a4 avant
    marlboro
    mods delete...figured it out after fixng shops error i had the boost setting too low causing the wastegate to stay open untill i took it and reset the memory...lol im a dumb ass
    -good news tho review on gizzmo boost controller coming shortly- so far its awesome now that its hooked up right now
    -vrt-
