For the High-beams to HID, the D1R type lamps with H7 adapter rings, should be used as that is the lamp used for open reflector optics. But the H7 high beam reflector is not properly designed for use with HID lamps. Using HID lamps in Halogen type reflectors will cause high levels of glare that could even effect the night vision of the driver of that car. The high beam D1R lamps would also need a ballast for a total of 4 ballasts. The 2 OEM ballasts fit the housings, then the two high beam ballasts would have to be remote mounted nearby. The HID lamps won't be "happy", unless only used when there is no chance of oncoming traffic that will require the highs to be turned off, then allowed to cool down for a few min before turning on again, frequent hot restrikes, require very high restrike voltage to start the arc when the capsule is still hot, and frequent hot restarts will reduce the reliability and useful operating life of the lamps severely.
