Results 1 to 8 of 8
Thread: inHG problem..?
    Sep 27 2008
    inHG problem..?
    installed ecs vent boost gauge, boosting about 10-11psi stock. but not really any inHG. isnt that suppose to be around 10-15? its maybe gettin down to like 1 or 2. no leaks to my knowledge, wondering if anyone had any suggestions?
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Re: inHG problem..?
    Does the "-13 vacuum ?" thread not too far up help you at all?
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Sep 27 2008
    Re: inHG problem..?
    not really, atleast his is at -13, mines not pushing past -2
    Jun 30 2007
    Raleigh, NC
    Re: inHG problem..?
    check where you have your boost gauge hooked up. any pictures? are there any spots near the back of the motor where you see an excess buildup of an oily grime?
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Re: inHG problem..?
    The 10 psi sounds about right for stock (anywhere between 7-11psi). For the vacuum, you should be at 20 InHg when at idle. If you're not able to get the gauge to move down, check all connections to make sure everything is on secure.
    If you're certain that you do not have any vacuum leaks and still can't get a proper reading, then there might be a fault with the gauge. In that case, you'll need to contact ECS to get a replacement (should be covered under warranty).
    USP CLUB MEMBER #34
    Sep 27 2008
    Re: inHG problem..?
    if i had a vacuum leak wouldnt it set a code? my check engine light has never been on, and VAG shows no codes. i own an auto repair shop so i have acces to all that stuff. ill take a pic where its hooked up so u can see. thanks for the help
    Sep 27 2008
    Re: inHG problem..?
    [IMG][/IMG]
    [IMG][/IMG]
    thats where i put it. is that where its suppose to go?
    Feb 23 2004
    Stow, OH
    Re: inHG problem..?
    Having a vacuum leak won't necessarily throw any codes. Can't view the pic right now (blocked at work), but as long as you followed the instructions, you should be ok. Just double check the connections to make sure everything is on secure. After confirming that, you may need to do a pressure test (or soap bubble test) to track down the culprit.
    USP CLUB MEMBER #34
