Results 1 to 22 of 22
    Registered Member Two Rings
    Jul 16 2008
    2001 Audi A4 2.8L Quattro
    Chesterfield, Virginia
    Goin About Turboin A 2.8
    How would you go about turboing a 2.8?
    Sep 23 2007
    Re: Goin About Turboin A 2.8
    trade it in for a 1.8t lol idk wouldnt you need 2 because its a v not in-line?
    Jul 16 2008
    some of the guys said that you could use an s4 kit but i dont know how that would work.
    Senior Member Three Rings fernando's Avatar
    Mar 06 2008
    01 A4 1.8T, 1998 Volvo S70 T5
    Maple, Onatrio
    Quote Originally Posted by audiornothin View Post
    well first thing that you should take into consideration before you even start to think about this build is howmuch money are you thinking to spend????
    2.8 engines are not designed to be boosted, so if you are gonna boost them, either you build it properly or your better of doing either a 1.8T or 2.7 TT swap
    GT2871R *Kinetic Motorssports FMIC * VME 4300 HID lights * Turbosmart DV * Revo BT Tune * APR catback exhaust system * custom vent boost gauge * custom vent wideband gauge * zimmerman crossdrilled front rotors with Hawk HPS pads * SB Stage 4 clutch * Neuspeed shortshift kit
    Jul 16 2008
    how easy would it be to swap a 2.7 TT
    Veteran Member Four Rings ProOnThaSnow's Avatar
    Oct 10 2006
    97 Civic HB 6266'd K24 build/1992 NA1 NSX/03 Yukon/01 F350 CC PSD
    S1 T1S R25E MT
    You're best bet in this scenario would be a remote mount turbo setup (i.e. off the exhaust).
    Actually, I take that back. Your best bet would be to sell it and build a 1.8T, seriously. Unless you're EXTREMELY mechanically inclined and have the tooling to build such a ride, I wouldn't consider it.
    And that would be the least of your problems. Try figuring out how to tune it first.
    Mar 06 2008
    Maple, Onatrio
    there is no such thing as an easy engine swap....u will need motor harness, ecu, drive train....but i can tell you that it will be a lot easier than to build a 2.8 t...and cheaper too
    Jul 16 2008
    then how would you go about turboing a 2.8
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    SEARCH! its been covered millions of times,
    yes you can do it with very deep pockets, there is a guy here in WA who has a TT 2.8 and it flys. but it cost a shit ton to build
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Jul 16 2008
    much appreciated guys. Ill research it but if its too expensive itll have to wait a while.
    Or would it be better to just pes supercharge it?????
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    if you really want to stick with the car you have, go for the pes s/c kit. you can only run low boost for the same reason with turbo (weak internals). IMO, your best option is fixing whatever it needs to achieve a good/great condition. do all the repairs yourself to avoid high labor costs, then sell it when you find a better powerplant (1.8tqm, s4, a6 2.7tqm, 2.2T). This way you can have a great daily driver with exhaust (optional) until you can afford to upgrade.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Mar 06 2008
    Maple, Onatrio
    to turbo charge it, when all is said and done you will probably be over 15K to do this turbo build....and that is a conservative number, depending on how big of a turbo u wanna go and boost numbers
    Senior Member Three Rings LowSantorin's Avatar
    Oct 19 2007
    Dub State
    Quote Originally Posted by JaVa View Post
    Who? and is he on NWquattro?
    Mar 17 2008
    97 2.8 5spd quattro
    wa
    remote turbo seems like it would be the most logical layout for this illogical plan.
    as for supercharging and weak internals, would installing some forged rods,ARP studs, bearings etc. solve the issue of high boost? i dunno for audis but for mk3 supras you can get great internals for 1-2k
    Apr 05 2007
    Bend
    just buy a turbo and weld it to the exhaust under the middle of the car with a filter attached. Run it into the intake manifold and tune it with an ebay tune. Done.
    My B5's For Sale PM ME!
    UberFellas
    stanceworks.com
    ^^Superior^^
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Quote Originally Posted by a4fann View Post
    Lol, that was funny.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    theres a cat running around with a 2.8 with a urs4 turbo on it in my hometown, he had to knock back the firewall and a few other things to get it to fit
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Veteran Member Three Rings Sigma 3's Avatar
    May 23 2005
    Tricities Wa
    "to turbo charge it, when all is said and done you will probably be over 15K to do this turbo build....and that is a conservative number, depending on how big of a turbo u wanna go and boost numbers"
    The car he is refering to cost over 16k when it was done. it would be cheaper to do know but im not sure by how much.
    16 k will get u a stage 3 s4 fwiw.
    However a single turbo on a 2.8 would be half that cost.
    pm makk and ask him about a single turbo for your car.
    Originally Posted by FNK re getting more power from a 2.8 a4
    "Paint the exhaust and intake with Ceramic paint (heat repellent), thus increasing the exhaust velocity, thus less striction = more Power"
    Oct 29 2005
    10speed
    San Francisco, CA
    I might have something available in the future too but who knows nowadays
    - Clint
    Veteran Member Three Rings xraycer2012's Avatar
    May 28 2008
    B8.5 S4
    unless you can tune a car with a standalone setup like the one from 034, don't bother
    ‘23 RS6
    '14 S4 Nogaro Special Edition - Sold
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by xraycer2012 View Post
    you could do an S4 ECU
    - Clint
    Q7, Q7, F-type manual
    exactly. get the s4 wiring harness and I bet you could make it work. it wouldnt be that much more money than the guys going gt's on s4s already pay.
