Results 1 to 6 of 6
    Jul 21 2008
    Phoenix
    Need help with a thumping noise - B6S4
    Intermittenly now when I turn the car off or just after I turn the car on the vehicle will make a thumping noise coming from what sounds like the bottom of the vehicle.
    Just after I turn the vehicle off intermittenly will make 3 thumping noises. Thoses same 3 thumping noises are there intermittenly when I turn the vehicle on immediately afterward.
    The 3 thumping noises happen within 1 second and it's loud and distinct.
    Any ideas???
    Thanks
    Registered Member One Ring Callsign_Jester's Avatar
    Oct 17 2008
    MKII Golf VR6 Turbo
    Annapolis, MD
    Re: Need help with a thumping noise - B6S4
    initial guess would be mounts (either motor or tranny) does it do the same under hard acceleration/deceleration?
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Exhaust rattling around maybe? Is the car all stock?
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    Jul 21 2008
    Phoenix
    Car is all stock manual transmission. It only doees it right after I turn the vehicle off and right after I turn the vhehicle on. It doesn't make any noise upon acceleration.
    Senior Member Two Rings B6_Rakete's Avatar
    Apr 17 2008
    '04 S4 Avant 6sp, '06 330i 6sp
    I'm going to venture guess that the exhaust is loose. Maybe a hanger became disconnected?
    Sep 18 2006
    So Cal
    Yeah sounds like exhaust to me. Crawl under the car and see if you can spot anything that may have come loose. There are hangers in the center section of the cat-back portion as well as at the rear near the mufflers. If one of those broke or came loose, I bet that's what it is.
