Results 1 to 11 of 11
    Apr 20 2007
    Long Island, New York
    Does anyone use Oettinger 4th,5th taller gear
    If so, could you please provide a quick review/opinion on it. Thanks
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Does anyone use Oettinger 4th,5th taller gear
    I would like to know also, I think that really it's just TDI gears w/ the Oettinger name.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 20 2007
    Can I get the TDI gears from someone/company in the states? Whats involved in changing out these gears? Aproximate cost of this job? thanks
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Look on the oettinger website, those look like the OEM part numbers.
    Installing them would pretty much require a total teardown of the entire tranny
    -Sami-
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    or you could just get a 2.8 tranny
    Quote Originally Posted by JBM View Post
    or just the 2.8 4th and 5th gear parts. a used tranny would probably be cheaper though.
    contact via email please.
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    it wouuld be neat
    Mar 21 2006
    Lakeland, FL.
    A 2.8 trans will be stronger, so putting 1.8 first thru third gears sets would be better then upgraded the 1.8 trans.
    I'm back bitches!
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    Quote Originally Posted by dirtybrd View Post
    are you suggesting swapping the 1.8 1-3 gears into a 2.8 tranny?
    i've herd that the 1.8 1st gear is a weak link, is that true?
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Mar 21 2006
    Lakeland, FL.
    B5 1.8 gears, sorry. If you plan on beating on the try having the cryo treated etc. before installing them. There has been B6 2 first gear failures that I know of, if you ask the people that broke them you'll probably find out that they were doing frequent lauches with a car load of people, ...Clint?
    I'm back bitches!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I plan on doing something like this during the winter. I was going to use my 1.8 trans and find a TDI 5th gear. Then cryo treat all the gears and put all new syncros in. You can get the gear from a few people on here. I just haven't had the time to start planning it.
    -Doug
