Results 1 to 28 of 28
    Registered Member Two Rings KingKosoko's Avatar
    Mar 07 2008
    2008 audi A4 2.0 or 2009 quat
    isit likely to fit a intercooler on a b6/b7 s4 or rs4?
    Can a small front mount inter cooler be added to these cars with out any bumper mods or cutting. Also does coolant pump run off the engine or is it electric.
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Re: isit likely to fit a intercooler on a b6/b7 s4 or rs4?
    Quote Originally Posted by KingKosoko View Post
    Why would you want one?
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Registered Member Two Rings Raudi 4.2's Avatar
    Oct 01 2008
    nothing
    nv
    ummmm they'r n/a... no need for an intercooler... unless is s4 or rs4 is really special
    In, Out and Around...
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    i want to put an intercooler on my B7 s4 so it would look cool. I just think its an ultra cool idea for people to see a front mounted intercooler through the front grill even though its not connected to anything. And Im convinced it would definitely add 25 whp.
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Quote Originally Posted by Beelzeebub View Post
    NICE
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    Veteran Member Four Rings KareemA4's Avatar
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    Seems like a cool idea
    Registered Member Four Rings cerfus's Avatar
    Oct 16 2007
    Germans
    Scottsdale
    do it, you'd be the pioneer of such a mod!
    ///Mcars
    looking for a sileighty..
    E39 M5 DD full Hamann exhaust h-back/ Hamann CF splitter/ Hamann C Diffuser/K&N intakes/ecu tune more to come.
    Keep your eyes peeled DG, CRFS coming your way!
    Senior Member Three Rings mitchholmstrom's Avatar
    Jun 22 2008
    Audi B6 S4
    anaheim hills, ca
    lol @ this whole post.
    2005 Audi
    :: Mods ::
    : Devries National - Stage 1 Weight Reduction
    : Euro Plate = Z3KS S4 - 08/08
    : Valentine One - 06/08
    : Painted Gloss Black Upper and Lower Front Grill - 09/08
    : Painted Flat Black Wheels - 09/08
    : RS4 Rear Swaybar - 10/08
    *OPEN FOR SPONSOR*
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    Bartender, I'll have whatever he's ^ having.
    B6 S4 Avant: Nogaro / JHM Tuned/ Piggied / Milltek Non-Res / JHM SS Trio / Hardwired V1 / SS Brake Lines / CC Mod / Stern Snub / LED License Plate / 18" TSW Vengeance / 20% Tint / DIY Blackout Grill / Black Window Trim / Thule Bike-Ski-Fishing Pole Rack / Full Timing Chain at 68k oh wel...
    just to play devil's advocate... i think he has an a4, and just posted in the wrong forum.
    Oct 01 2008
    nothing
    nv
    Quote Originally Posted by iconoclast View Post
    no he didn't
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    no. read the title of the thread... he said s4 or rs4
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    derf... a4 avatar through me off.
    Mar 07 2008
    Re: is it likely to fit a intercooler on a b6/b7 s4 or rs4?
    I ask because i am seriously contemplating a sts turbo setup. The m5 has a rear mount turbo set up by a tuning company so why not lower the compression and force feed these engines? something similar to the 2003 rs6. This is the only way to add big hp with out increasing rpms. Dont believe then do some research.
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    good luck with that......let us know how far you get with that.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Veteran Member Three Rings Jdubya's Avatar
    Apr 05 2006
    05 S4
    Dayton Ohio
    I think a rear mount setup would work. I've been thinking about doing it also. The only problem is going to be tuning.
    FI DP | FI CB | JHM IM | JHM TUNE | JHM N20 | SB STAGE III/LWFW | PORSCHE BBK | BBS CH | KONI/H&R
    May 30 2007
    MA
    Wait what? Increase horsepower without increasing RPMs? This is where your research should begin....
    2014 R8 V10 - Gated
    im not sure which set up youre referring to however, the most powerful M5s are usually supercharged...
    http://www.discovery-automotive.com/..._Content&id=30
    Senior Member Two Rings ARCH NME's Avatar
    Mar 07 2008
    SPRINT BLUE DTM S4
    queens, new york
    LMFAO....
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    Quote Originally Posted by Jdubya View Post
    Im sure you can find a company to do your tuning.. the big problem that you are going to run into is getting a charge pipe from the back of the car to the front without cutting a bunch of stuff.... I've looked into this option a lot. With the dual exhaust, driveshaft, brake lines, and all the other crap our audis have on them its almost impossible to get piping where you want it to go.
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Question / threadjack: I know that N/A engines like ours especially feel and are significantly faster in the really cold morning, etc. Is there any way a FMIC application could replicate the colder, denser air into the engine? Not realisticaly, right?
    idk anything about N/A engines benefiting from cold air... however FI engines could pack the lower intake piping with ice or dry ice on the IC.
    also water, meth injection, or plumb nitrous into the intake.
    Apr 05 2006
    05 S4
    Dayton Ohio
    Quote Originally Posted by Cargo8 View Post
    Intercooler, no. Nitrous. Oh yes.
    Veteran Member Three Rings UberDave's Avatar
    Mar 15 2008
    TX
    Rear-mount turbos don't need intercoolers because of the long run from the turbo to the engine. And there isn't any room anyway.
    Veteran Member Three Rings 3 bar's Avatar
    16 SQ5, 14 A7 Tdi, 91 Corrado, 02 Passat wagon, 99.5 A4 TQM
    Greensboro NC
    Theres a thread on a S4 with a rear mount turbo. Do a search. Also I have heard that meth injection works well on N/A cars has anybody explored this option?
    2004 Atlas Grey A4 Avant
    1999.5 Volcano Black Audi A4 1.8TQM
    2002 VW Passat wagon 1.8t 5 speed
    1991 VW Corrado 1.8t w/matching trailer Waterfest 03/04 winner (show)
    1980 Chrysler Cordoba LS 371ci 450hp 12.68(go)
    Apr 05 2006
    05 S4
    Dayton Ohio
    Meth will work if:
    Your car is pulling timing
    You can add timing
