JHM SSK
Professionally installed at JH Motorsports in Lathrop, California. Due to excellent Customer Service I ended up with the 1" shorter shaft and a stock pushdown reverse spring. Shifts are very crisp and solid, makes rev matching down shifts a breeze because my old stock shifter was quite notchy, especially going into 3rd. A definate must have mod if you enjoy mashing thru your gears!
DIY Plasti-Dip Shift Surround
My stock surround was looking very worn compared to the rest of my interior so I decided to re-finish it with Plasti-Dip. It's a rubberized paint spray you can purchase at your local Home Improvement store for under $9. All I did was clean the surface to rid any oils, let it dry, sprayed 4 heavy coats with 30 min. drying time between. I also removed and painted the silver trim around the surround separately as well and slapped my old shift boot back on
