Results 1 to 7 of 7
Thread: Faulty MAF?
    Veteran Member Four Rings rocky.ca's Avatar
    Aug 24 2008
    Faulty MAF?
    I VAG'd the G/s and at WOT i record 103 g/s I am assuming that this is a little low. Could it be due to a clogged air filter? The readings arent eratic, it just stops at 103gs at redline... Also, i have the code 17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High P1113 - 35-10 - - - Intermittent does this mean that my O2 sensor is bad, if so what one?
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: Faulty MAF?
    not sure on the MAF but you need an 02 sensor. Thats the first one or the one closest to the turbo.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Aug 24 2008
    Re: Faulty MAF?
    thats what i was thinking... thats kinda unfortunate :( another 150 bucks to spend on repairs......
    Dec 05 2007
    Re: Faulty MAF?
    Not necessarily. Clicky Click. I ordered replacements for both 02 sensors from him. The only issue is they do not come with the connector, but it has plenty enough slack for you to just splice them into your existing harness and seal with shrinking tube. This is considering that there is nothing wrong with your connector and it is the sensor itself which is faulty. And yes, they are brand new Bosch units (no, I do not know why there is no connector sent with it. but for the price why ask).
    Aug 24 2008
    Re: Faulty MAF?
    work well? ive heard bad things about the universal units but if it does then screw it..... under 30 bucks shipped, score!
    Dec 05 2007
    Re: Faulty MAF?
    When I purchased mine, he had a lot more in his inventory. So, I did not get the Universal ones as he had the specific ones for my vehicle in stock at the time. I paid like $55 for the secondary 02 sensor and maybe $28 for the primary.
    Aug 24 2008
    Re: Faulty MAF?
    anybody else have experience with this o2 sensor?
