Results 1 to 4 of 4
Thread: podi install
    Registered Member Three Rings P3RryaudiA4's Avatar
    Oct 15 2007
    2000 Audi A4 quattro
    Brocktron Ma
    podi install
    hey does any1 know if i can use the vag connector for my igntion instead of using the actual igntion wire, scince i can not find it? this is for the stepper motor install on a b5 not a b6 so the writeup is different and i cant figure out wich wire is the igntion.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: podi install
    I use my VAG connector, forgot which wire I tapped though.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: podi install
    you're tappin the power for what exactly? cant you use the posts for that?
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Jun 04 2007
    Austin/DFW, TX
    Re: podi install
    I tapped mine from a post.
    My 5-Speed Swap DIY
    - B6 USP
