Results 1 to 7 of 7
    Jul 19 2008
    MIlwaukee, WI
    Pictures of timing- is it right and a CMP/ lean code issue
    A lot of people have told me that my timing is off from the cam to cam, so i took the damn valve cover off today and took some pics. Does this look right to you guys
    here is crank to cam timing pics
    and now the cam to cam timing
    anyways i built the motors drove fine for 500 miles, now is throwing a CMP (p1338) short code, replaced the sensor, checked voltage from terminal 1 to 3 and have 5.3 V (min 4.5 V per bently) then checked the resistance from the ECM to each of the terminals on the clip all read .5 ohms ( bently states 1.5 ohms max)...still the check engine light is on
    when you start in the morning idle will fall twice under 600 rpms then back up to normal, at stop lights it with idle then slowly raise idle till it sits somewhere between 1200 and 1000 rpms.
    Compression is 155psi+/- 5% in all cylinders on 4 cranks of the motor, can't find a boost leak/ vacuum testing with compressed air. Just can't figure this out...Bad ecu the book says if the wiring to the cmp is good and a new cmp is in place...idk?
    Senior Member Two Rings tonelee1316's Avatar
    Oct 11 2006
    rancho cucamonga
    Re: Pictures of timing- is it right and a CMP/ lean code issue
    the cam to crank timing looks like its off just a little bit off like almost half a tooth
    Genesis Autosport
    Evolution Racewerks
    Jul 19 2008
    MIlwaukee, WI
    yea i noticed that also, but would that cause the cmp code?
    Veteran Member Three Rings prodrive's Avatar
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    I think it's acceptable ,I saw a lot of car which is off a half tooth.
    Just A4 ... A4 which we know
    2.0L - HTA35 - Cat3658 -Autronic EMS - Autronic 500R CDI etc..
    Feedback: Clicky
    Jul 19 2008
    MIlwaukee, WI
    i added new pics of the cam to cam so you guys can see its 16 links
    Oct 29 2005
    10speed
    San Francisco, CA
    the cam timing on the valve cover does look off, and yes that will give you a code unless its SPOT ON
    - Clint
    Oct 11 2006
    rancho cucamonga
    x2
    Genesis Autosport
    Evolution Racewerks
