Results 1 to 12 of 12
    Established Member Two Rings nytoy's Avatar
    Aug 13 2008
    Rochester, NY
    Getting the damn cat off the downpipe!!
    I saw the DIY and this is the third day I've spent on this damn thing, it's driving me crazy! I have a test pipe I'm trying to put on, and can't get at these bolts, I've dropped the entire exhaust and removed the rim, got one off and they are like a 13 or 12mm but nothing fits.
    Do I have to remove the cat through the top or can it be dropped out the bottom? I have all heat shields removed as well. argghhhh
    '99 Audi A4 Avant 1.8TQM Silver (GIAC Stage 1, Cat-delete)
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: Getting the damn cat off the downpipe!!
    Throw a ball of yarn in your engine bay :-p
    Okay heres what you do: Disconnect the cat from the turbo, and pull the cat/downpipe thrugh the top of the engine bay. It will require lots of twisting and turning but it will come out of the top. You can then disconnect the downpipe from the cat outside of the car where you can get more leverage. Installation is just reverse of that.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Mine came out the bottom, but the flange fell off the turbo side of the cat which made enough clearance with the trans mount out of the way.
    It's a bitch to do in the car, even worse with an auto/Tip car.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Quote Originally Posted by t1demont1 View Post
    x2!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Oct 15 2008
    2001 A4tqm
    Lincolnshire
    same with me, i took it out the top when i did a clutch job awhile back, but, i had the right front drive axle off, and i had to lift the car up really high so there was more room to twist. the car is heavy though, id have a friend lift it for you. or a jack.
    2001 a4tqm
    giac| apr snub mount| eibach prokit| 710n| ebc greenstuff & zimmermann rotors| fidanza flywheel| 15% rear tint, 35% front| HFC | S4 seats | Buddha figurine | Passport 8500 x50 linked with zr3 laser shifters
    Aug 13 2008
    Rochester, NY
    I have tried all day I cut it after the downpipe and still can't get it past the oil return hard line to the turbo out the front, how the hell did you get the air box bottome out? I can't get it out the bottom either....god help me!!!
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by nytoy View Post
    There airbox is only held in by one screw and thats it
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    The airbox is held in by one 10mm bolt on the fender support, then it has these rubber things that hold it in place on the frame rail thing, but just take the 10mm bolt out and pull, it should come out easy.
    Aug 13 2008
    Rochester, NY
    Quote Originally Posted by arorem View Post
    the bottom of the airbox has the two rubber supports that go into the frame rail, it is ok if I just pull on it hard? I couldn't find a way to loosen them.
    Thank you for everyone that responded, very helpful, I'm hoping today to finish this project, it's been a week!
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    yeah, just give it a good yank. it'll come out. cant believe it has gone on this long, good luck. BTW when i did mine they bolt became so rusty that no metric sockets were fitting, ended up fitting with a standard socket, dont remember the size, just saying..
    Aug 13 2008
    Rochester, NY
    got it out today thanks god, new test pipe is on...
    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    for future encounters with anything exhaust (or rust), pb blaster can help, its good stuff
    2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2013 Phantom Black C7 S6 Stage 3 | 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
