Results 1 to 11 of 11
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Brake question - Confused!
    My brakes pads are all worn and my rotors are showing signs of wear and littleness so im looking to upgrade, mostly at b5s4 brakes. What is the exact parts lit? This is what i know ill need:
    b5s4 rotors
    set of pads
    calipers
    new lines
    fluid
    now do i also need carriers or anything else im not even thinking of? Im doing this on the cheap so if anyone knows of any deals or good prices post em up! Oh and any specialty tools??
    barrett
    2019 SQ5 Prestige
    Apr 01 2007
    houston texas
    Re: Brake question - Confused!
    ttt
    2019 SQ5 Prestige
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    The b5s4 brake upgrade is basically an upgraded caliper over the stock one. Therefore, new carriers are not needed but the rotors are larger than stock. All you do is order b5s4 pads to go with the new calipers. I'm not sure if SS lines are the same for both cars.
    EDIT: ttt in just 4 hours? geez.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Sep 01 2007
    Quote Originally Posted by wolfdog View Post
    The b5s4 brake upgrade is basically an upgraded caliper over the stock one. Therefore, new carriers are not needed and the rotors are the same size as stock. All you do is order b5s4 pads to go with the new calipers. I'm not sure if SS lines are the same for both cars.
    ABOVE = FALSE
    b5s4 brake upgrade uses & requires 321mm rotors which IS WHAT actually makes it an upgrade. B6 1.8T= 288mm, B6 3.0= 312mm(also a bolt on for 4cyl). B5/C5 2.7T HP2 brake carrier format is unique and carrier generally will come with used calipers. Pad choices are limited and magic pads for HP2 are a bit pricey due to 8 pad set. Unfortunatly my mind is blank on the brake hydraulic lines required for B6/HP2 combo at the moment.
    Edit: The quoted post I contridicted apparently has been updated for accuracy
    Todd
    Autobahn Premier Service
    94 UrS
    81 Rabbit Truck
    00 A4 V6 Avant Project Car Currently in Ice Racing Trim (lost custody)
    01 S4 Avant Project Car Currently in carcass phase
    Nov 22 2006
    Thanks, my bad. The calipers are also more than one piston if I'm not mistaken, making better clamping as well as the heat dissipation from the larger rotors.
    2002 A4 TQMS
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    B5S4 caliper actually integrates the carrier and caliper, so they really aren't normally separated. It's unlikely that someone would sell you a caliper without the carrier.
    Apr 01 2007
    houston texas
    Quote Originally Posted by Mike@PureMS View Post
    Well maybe i just dont have a good enough education about it. I was looking at rockauto.com and you can get s4 calipers for $280 shipped new. heres the link tell me if the carriers are included.
    http://www.rockauto.com/catalog/raframecatalog.php
    its under caliper also it says theres a core charge of $50 whats up with that?
    barrett
    2019 SQ5 Prestige
    Jun 08 2008
    Calgary AB Canada
    you get the core back if you give them back your old calipers
    Apr 01 2007
    houston texas
    ^^^cool anyone know if id get the core charge back even though id be sending in OE 1.8t calipers?? cause that would be a deal!
    barrett
    2019 SQ5 Prestige
    Mar 27 2005
    The Cold North
    with the B6 S4 & B7 A4 calipers readily avalaible there is no reason to waste your time on the old B5 S4 calipers. The old HP2 calipers also were known to limited wheel choices when compared to many other calipers.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Senior Member Two Rings inaforest's Avatar
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    does this mean b6 s4 brake calipers are bolt on?
