Results 1 to 24 of 24
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    So I just got an error on my N276 ( Fuel Pump )
    Me and the guys of Dubbers inc. ( Aka VolksAudi ( Thank you VW of America )) where driving up to Bradenton for Fixx Fest, and from no where while overtaking a car the A4 went in to limp mode, started misfiring and wont build up boost. I managed to get it to a dealer and they replace the fuel pressure sensor, but It did not fix anything. Apparently Its my cam and follower that took a dump. Ill keep you guys updated.
    Tomorrow the car is getting towed to Audi of Naples.
    Ps. The car just came out of the dealer yesterday for collapsed motor mounts.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Re: So I just got an error on my N276 ( Fuel Pump )
    and youre getting this all covered under warranty!?
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    damn! that really sucks man, idk how your gonna hide all your mods but all the power to you if you can get it done for free
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by a4dc89 View Post
    I don't hide them, when I stopped by the dealer at Naples, I had the car show and track ready, It caused such a big impression on the service department and on the other customers they took care of me just like home. Apparently no one mods their cars there.
    However here at home I do know people, and do some tinkering with my mods to make it seen as stock as possible. Since there is a recall on the cam and the follower this should be an easy one.
    -EI AL CAI.
    -Driver Mod.
    Nov 12 2007
    Grand Junction, CO
    If this goes smoothly for you, I would be very, very surprised. I don't care if it's bad for the engine or not, if you have coolist Mis Water/Meth Injection they're going to say your mods broke the cam follower and void the warranty. Unless they are really cool. Then you'll be all set....but I don't think you're going to come out of this w/out paying anything. Sorry dude. Good luck.
    Oct 14 2006
    MK6 Jetta
    South,FL
    Dont worry, Im pretty sure it will go just fine.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    did audi say that it was your cam and follower or are you assuming this to be the problem? fuel pressure sensor problems can mean several things.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    good luck bro, thats what u get for passing me at 150 lol
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by RedS-line View Post
    Im assuming it is either or, since when I stopped by the dealer they replaced the pressure sensor, and everything else seems fine. We had already replaced the follower cap once, but who knows. Maybe the pump is seized.
    Im towing the car back tonight, and I will know for sure tomorrow.
    -EI AL CAI.
    -Driver Mod.
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by Ih8OEM View Post
    Yeah, about that ...
    -EI AL CAI.
    -Driver Mod.
    Aug 31 2007
    Miami
    Quote Originally Posted by HID View Post
    oh burn
    IG | @fukn_fafa
    Mar 19 2008
    ok well since youre assuming then heres some help. if you get your car back and they replaced the same sensor again, then bring your car back and tell them to stop being stupid. it took several trips to the dealer before i asked for AoA to help. AoA pointed to a Low Pressure Fuel Pump (in the actual tank) that was faulty. good luck
    2019 S5 BO.SS
    2009 R8 6 Volt :)
    Oct 14 2006
    MK6 Jetta
    South,FL
    Im going to get the dolly to go get the car, and tomorrow surgery begins.
    -EI AL CAI.
    -Driver Mod.
    Oct 14 2006
    MK6 Jetta
    South,FL
    Well, the fuel pump took a s**t. The cam follower had a hole done by the rod that drives it and the rod wore off on the cam. Cam is bad as well.
    Dealer is taking care of it, just have to return the cars ECU to Audi binary, since revo wont let them check for codes.
    -EI AL CAI.
    -Driver Mod.
    Aug 31 2007
    Miami
    glad to hear everything will be ok, and you will be on the streets once again!
    IG | @fukn_fafa
    DUH! an Audi
    los angeles, CA
    one day, i am going to miami to hang with the big boys! haha
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    Is this the first you're experiencing of the dreaded cam problem? or did you get it replaced and it happened again?
    Just curious because I had mine replaced and am hoping the updated parts won't take a sht too.
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by Quattro View Post
    More than welcomed
    -EI AL CAI.
    -Driver Mod.
    Registered Member Two Rings E46HoodRich's Avatar
    Oct 01 2008
    bmw e46 328i
    Miami
    update?
    Oct 14 2006
    MK6 Jetta
    South,FL
    Still at the dealer, waiting for their call today.
    -EI AL CAI.
    -Driver Mod.
    Oct 14 2006
    MK6 Jetta
    South,FL
    Well, I still have a warranty on my car, however I'm taking it to my local shop and doing it there. It has been too much of a hassle to deal with this dealer ( After they told me to bring it in with every thing on ). As soon as we get the cam Ill start posting pics of the resurrection process.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    good luck with everything your car is hot
    Mar 19 2008
    that sux about the warranty. keep us updated. whats it like driving 400+ hp on front wheel drive?
    2019 S5 BO.SS
    2009 R8 6 Volt :)
    Oct 14 2006
    MK6 Jetta
    South,FL
    Still have the warranty, but they dont want to do the job, because they are afraid of messing with something aftermarket and messing it up.
    Now about whats under the hood, Its only usable from third gear and up, on strictly dry conditions. I mean I can do a second gear roll, but it will light them up till third.
    -EI AL CAI.
    -Driver Mod.
