Results 1 to 40 of 75
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Cracked 034 Manifold
    well this is my second 034 high flow manifold for my 2871r and guess what?! it cracked again in the same spot as the last one This time i think i will be going with the ATP HF manifold
    Aug 16 2007
    Buffalo NY
    Re: 034 Manifold
    why can nobody make a quality manifold for the 1.8t?
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Re: 034 Manifold
    SPA does.
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: 034 Manifold
    Quote Originally Posted by AudiRacerS4 View Post
    We have never had a reported failure of the High flow manifold.
    Please take pictures and send it to [email protected]
    I will take care of it.
    Thanks.
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Re: 034 Manifold
    ^hooked up.
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    Re: 034 Manifold
    Get the SPA manifold. Definitely looks quality.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: 034 Manifold
    You have an eliminator right?
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: 034 Manifold
    spa is a t3 manifold, doesn't he have a t25 flange?... spa is out i think, although thatd be a good choice.
    Feb 26 2006
    Earth
    Re: 034 Manifold
    He has an eliminator
    only stock and eliminator manifold will work.
    Sep 24 2005
    always in design
    Re: 034 Manifold
    Quote Originally Posted by njm23 View Post
    SPA has a T25 manifold as well.
    Full Lifetime warranty is always a plus
    Oct 28 2006
    Re: 034 Manifold
    Quote Originally Posted by Issam@034 View Post
    Thanks.
    I'll take some pics of it tomorrow issam
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: 034 Manifold
    Quote Originally Posted by bassed View Post
    Boo for no port for an external wastegate. Guess I'll have to just start saving for a T3 turbo & the T3 SPA manifold :-)
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: 034 Manifold
    Quote Originally Posted by GetBoosted84 View Post
    That is because most T25 flanged turbos are internal wg.
    Aug 16 2007
    Buffalo NY
    Re: 034 Manifold
    Has anybody cracked the OEM manifold? I think i may just keep that and deal with loosing 5hp lol
    Veteran Member Three Rings prey's Avatar
    Feb 03 2007
    2003 Audi a4 1.8 TQMS
    Parsippany
    Re: 034 Manifold
    That still sucks for you man, since its a bitch to remove and install it again..
    not only that, its time consuming. i wouldn't put a 034 one on since it cracked 2 times for you.
    good luck
    Prey
    2003 Audi a4 1.8TQMS Unitronic Stage 1+
    Oct 28 2006
    Re: 034 Manifold
    Quote Originally Posted by slopoke View Post
    yes the oem manifold cracks more
    Feb 26 2006
    Earth
    Re: 034 Manifold
    Quote Originally Posted by prey View Post
    good luck
    FWIW, the only manifold I have ever seen crack is on this users vehicle.Not one single user outside of AZ has ever reported to me that there manifold has cracked and as of the weekend I have sold over 45 of these manifolds.
    Oct 28 2006
    Re: 034 Manifold
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Re: 034 Manifold
    Ouchie!
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    Re: 034 Manifold
    dayum makes me think twice about buying a 034 mani now
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Re: 034 Manifold
    Ouch is right, hopefully Issam will send you a new one so you can swap it out with less down time. You should be an expert by now. I know just changing the stock one is a pain.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Oct 28 2006
    Re: 034 Manifold
    Quote Originally Posted by D's Avant View Post
    yeah and changing this one is an even bigger pita
    Veteran Member Three Rings dingguhlbary's Avatar
    Jul 17 2007
    New Jerzzzzzzzzzzzzzzzzzzzzzzz
    Re: 034 Manifold
    Thanks.
    that's customer service.
    i'll still buy from 034. things happen. and if this IS the only isolated case, then maybe something is wrong other than the mani
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: 034 Manifold
    do you have anything supporting the turbo?
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Sep 17 2006
    SLC, UT
    Re: 034 Manifold
    SPA does.
    stop spewing your SPA bullshit. everyone knows it's a great manifold
    how does that help him with his eliminator
    do you get kick backs from SPA everytime you mention them on a forum?
    if so, now we know how you paid for that 2.0l, tune, and car for that matter..
    i'd say turbo, but you prolly have the same deal with bullseye as you do with SPA
    Current:
    Previous:
    Oct 28 2006
    Re: 034 Manifold
    Quote Originally Posted by dingguhlbary View Post
    What the fuck is that supposed to mean...before you make assumptions maybe you wait to see outcome and how the situation is handled. no need to jump on anyones dick.
    Sep 17 2006
    SLC, UT
    Re: 034 Manifold
    i think the guy was just throwing out idea's.
    you know... helping.
    no need to be an ass
    Current:
    Previous:
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: 034 Manifold
    so much anger in this thread lol
    - Clint
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Re: 034 Manifold
    What did you do with the first one that cracked?
    Feb 26 2006
    Earth
    Re: 034 Manifold
    Thanks for the pics.Lets take this to email :)
    Sep 24 2005
    always in design
    Re: 034 Manifold
    Quote Originally Posted by sean1.8t View Post
    Excuse me SEAN! You have some audacious statements right there. Especially audacious when we're on a forum where I personally know and have met about 30 members, and am social friends with about 5. Did it occur to you ever that some of us are a bit more grown up and have had salaries and accrued some fun debt (car) now for the better part of a decade? I've had the title for a year and paid the Audi off a year early.
    Since you must know my total was 491.38 shipped for the Manifold
    I also have a 04' Jetta I make payments on, I also pay my student loans that I am still accruing, as I need another 1 to cover the next 3 years of my education for yes, now yes MY FUCKING 2nd DEGREE. Go play with the kids now, you little shite. I receive no kick back from SPA or Bullseye, however I do have a custom sponsored tune by UNITRONIC, hence my boothing it at shows for them, which thanks to me led to 2 other files now being run on a ton of cars. The car is also Sponsored by STRASSE who wanted to try out a new to the scene turbo, hence the BULLSEYE, they had always used GARRET prior, crazy Canadians. So Sean is there anything else you need to know? Need refrences? Images of receipts? I'll gladly post them up if you like, but do you really want to get pwn3d that bad?
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Re: 034 Manifold
    damn i always thought 034 was good stuff
    Oct 28 2006
    Re: 034 Manifold
    yes I have the stock turbo support bracket
    Oct 28 2006
    Re: 034 Manifold
    Quote Originally Posted by audiness View Post
    dont get me wrong i'm not knocking 034 by any means...everything on my car performance wise i have purchased from 034 and have nothing but good things to say about them. i have spoken with issam and we will see how correcting this problem goes I also appoligize if it seemed like i was angry but i'm already dealing with a melted ECU engine wire harness and now this so i'm pretty stressed and it's one more thing i need to remove from the car which means more added downtime. I'm a full time college student who commutes and this car is my DD so when it breaks it also affects other things
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    Re: 034 Manifold
    Rough thread, Sean, Bassed isnt getting anything out of it.....
    He just wants to share his good experiences w/ a quality product/company
    Just like he tried to get me to go bullseye and plenty of others.
    In other words, he just wants to everyone know that there is light beyond the brands that we are so used to.....and at the same time, he isnt knocking issam or 034
    That sucks KY, maybe its your dump reverberating and cracking that bitch :P
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    https://www.facebook.com/media/set/?...1463643&type=3
    Current: 1994 Mazda RX7 Chaste White
    DIY B5 Head Replacement Guide: http://www.audizine.com/forum/showth...al-and-Install
    Oct 28 2006
    Re: 034 Manifold
    Quote Originally Posted by Rosati View Post
    damnnnnn look who it is long time no see rob, hows the new job treating you
    Nov 17 2004
    Northern New Jersey
    Re: 034 Manifold
    Sup bro
    Good man, The stock market just shit the bed and I get to enjoy the ride up
    .....whenever that is.......
    Ill stop by thursday night man, can you bring your OBD scanner if you dont mind?
    Oct 28 2006
    Re: 034 Manifold
    Sup bro
    yeah i'll have it, look forward to seeing you maybe i'll have my car up and running before then...i have to finish ripping apart the whole engine harness and replacing it tomorrow
    Sep 17 2006
    SLC, UT
    Re: 034 Manifold
    rob = most stand up guy on the forums! period.
    i'd ask how you been but already got the update in your other thread.
    im actually driving around in a maxima that looks just like your infinity.. slow little buggers! haha
    Current:
    Previous:
    Sep 17 2006
    SLC, UT
    Re: 034 Manifold
    "pwn3d"?
    don't know how i can get "pwn3d" from my sarcastic post.
    again, the post was not literal. it was meant to illustrate how much you spew out your SPA and bullseye love when it is not even needed or relevent to topics at hand
    Current:
    Previous:
