Results 1 to 9 of 9
Thread: more sub help!
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    more sub help!
    So i got my system mostly hooked up, but it sounds weak and distorted...
    I tapped into the rear speaker wires, since they were directly above in the trunk, and got a high low converter hooked up.
    Any ideas or suggestions?
    Do i need a bass controller?
    Are there settings on the high low converter i need to mess with?
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Re: more sub help!
    details first bose or not?
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    Re: more sub help!
    well first you dont need a hi lo converer, just like i said in your other thread, you need to splice your RCAs into the stock harness. there is already a line level signal in the trunk
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Dec 08 2006
    Cincinnati
    Re: more sub help!
    The way he is doing it works perfectly too. Make sure everything is connected right. The PAC I35 I use has adjustable knobs on the top of it, I put these at middle. What type of converter are you using? Mess w/ gain etc on amp to no avail I assume?
    Veteran Member Three Rings europshhrc279's Avatar
    Dec 24 2006
    Miami
    Re: more sub help!
    When connecting a sub to the stock radio usually its not gonna sound very clear because as you increase bass to your sub your also increasing bass to your speakers. Stock speakers do not respond well to bass at all ..so you get a distorted sound. Im sure with an aftermarket radio that lets you control the sub on its own it would it would sound 10x better.
    99.5 A4 1.8T K04
    Tein s-tech springs/ Bilstein shocks, Painted lowers, Matte black S4 grill, "HD" Lip, Forge 007, KO4, Unitronics Stage 1 file, Evo Motorsports Intake, Center vent Boost gauge, Jensen Flip out, Pioneer 2-ways, Alpine Type R 10, Alpine amp. Open downpipe , 19x8.5,19x9.5 Falken rubber, Drilled and slotted rotors all around, Greedspeed Snub Mount, VMW Test Pipe. 6000k HID Low and fogs.
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: more sub help!
    Somethings up, i checked everything, but the subs arent hitting at all...
    gonna go to tweeter tonight and let them do it.
    Jan 07 2007
    Re: more sub help!
    crossover set correctly?
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: more sub help!
    idk, i think it might be the ground, who knows...
    im letting tweeter do it, i give up.
    Registered Member Two Rings
    Aug 19 2007
    central oregon
    Re: more sub help!
    Most people on this board are confused about the stock soundsystem. You don't "need" the hi-lo converter, skip it. You may have tapped the wrong wires, or have a intermittent connection between ground or the splice. Check them all and make sure you solder the wires instead of just "electrical taping" them. Do it right the first time. If you need anything just pm me. Good luck!
