Results 1 to 8 of 8
    Veteran Member Three Rings RAUDIS6's Avatar
    Oct 09 2006
    Stage 3 B5 S4, LS460, Mini S Countryman
    Need help, not sure how to mount this.
    Well it finally arrived in the mail today, what drill bit would you use to drill through your hood to mount this? It is going on my S6 Avant.
    Veteran Member Three Rings autophiles's Avatar
    Aug 25 2004
    '04 Discovery SE
    Wilmington, NC
    Re: Need help, not sure how to mount this.
    Quote Originally Posted by RAUDIS6 View Post
    That thing is sweet looking.. but I'm not sure how it'd look on a modern S6...
    Feb 17 2004
    Sterling, VA
    Well, I would determine where you want it and then whether anything underneath will be effected by drilling there.
    Then cover the spot where you want it with marking tape on both sides of the hood. Mark the base of the ornament against the tape with a pencil and then mark the drill points inside the base outline on the tape.
    Drill very slowly through the tape/paint/metal and do not force the drill. Use a fresh drill bit so that it cuts and doesn't just heat up the paint.
    Once the hole is drilled, use a small round file to remove burs in the opening. Then, I would apply a coat or either touch-up paint or some kind of primer/sealant to prevent the surrounding paint edges from lifting one the screws are in place.
    Peel the tape and install. You may want to cut out a rubber base for it to rest on. Like 1/8" thick to keep it from vibrating against the hood surface.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    now all you need is this in the grill!
    2004 Audi A6 2.7T
    Oct 09 2006
    LOL....I had a little to much happy hour that night, and could not stop laughing while I was typing.
    Senior Member Three Rings Chopstixs's Avatar
    Jan 22 2008
    2.8 Single Turboed A6/2011 Tahoe
    Va
    Don't do it!!
    Through out the years, People have used "Chopstix" to eat rice.........I do the same.
    C5 UNION MEMBER
    Veteran Member Four Rings MYDWAGON's Avatar
    Jul 08 2007
    Ohio
    Mount it on a metal bar and make a branding iron
    04 4.2 Allroad w/H-Sports-Full Tint-Armorcoat- RS6 Exhaust/Gutted Kitty-Flaps-Michelin Pilot Sport A/S Plus-Thule Box-OEM Trailer Hitch-226k
    Veteran Member Three Rings djez016's Avatar
    Sep 01 2008
    04 toureg /94 sliverado /98 e320
    Delaware
    well what you do is get a box and a pen place it in the box and ship it back to sender
    .....GAVE YOUR GIRL 4 RINGS NOW SHE AUDI.....
    http://www.cardomain.com/ride/3083923
