Results 1 to 11 of 11
    Established Member Two Rings Chr1sJohnson's Avatar
    Sep 28 2007
    07 Audi Q7, 83 CJ7, 07 Harley Night Rod, 67 Triumph Bonneville
    Charlotte, NC
    35 Watt HID kit issue DIPPED..HELP!
    I have an 35x2 watt HID kit. I'm now getting an indicator stating that my left headlight is dipped. When I try and turn my headlights on now, the left tries to turn on, but fails.
    It happened when I was driving for about 2 hours with the lights on.. and I pulled into a rest area, turned them off for about 5 minutes, then back on.. and bam.. dipped.
    I had this problem about 6 months ago, but it eventually fixed itself when I would turn the car off and back on a couple of times. What does this sound like?
    Overheated? Bad connection? Not sitting right? Short something? thanks in advance.
    (The brand of HID kit is rikensport btw)
    Senior Member Three Rings G-Bus's Avatar
    Aug 25 2008
    Montreal, Canada
    Re: 35 Watt HID kit issue DIPPED..HELP!
    You have to get 55 watt HID instead. The system works with 55 watts, if it pulls less than that, it thinks that it's burned and stops sending power thru.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    I had prolly the same problem. After driving in a hard rain for a while, car sat parked for a couple of hours and then it began going bad. But about 3 days after the problem went away, then a week later came back. It was working fine for maybe only 2-3 min, the problem was one of the ballasts, i just replaced it with a new one.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    one of two problems.
    It's either ballast or bulb.
    If it's a ballast, you can replace one.
    If it's a bulb, you'll need to replace both.
    Bulbs have burn-in time whereby they change color within the first 200-300 hours of burning time and eventually "set" on their designed color.
    So you'll have really funky looking bulbs if you only change one.
    GL
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    with aftermarket HID kit,
    always TURN HID on AFTER you start-up engine.
    always TURN HID off BEFORE you turn engine off.
    else, you may get DIPPED bulb soon.
    (u'll hav to replace the HID bulb)
    however, lastest aftermarket HID kit now regulates wider range of voltage and perfectly suits with 55W.
    Sep 28 2007
    Charlotte, NC
    Quote Originally Posted by aaaudiprotein View Post
    I let the car sit over night and tried it again and it's not working. If I unplug and replug the balast connection, you can hear the ballast having a connection for a second then doesn't. Everytime I unplug and replug the lamp blinks slightly, but doesn't turn on.
    I'm trying to figure out if it's the bulb or ballast. But now that I look at it, this company Rikensport doesn't sell bulbs, only the entire kit.
    This is so frustrating! Thanks for the info guys..
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Like i said, my bulb was working maybe for 2-3 min. I'm 80% sure it is your ballast. But anyways, i ordered mine from VVME, takes them 3 bz days to get here to IL. I do have 2 spare bulbs (6000K) if u are interested.
    Registered Member Three Rings ILikeBigBrakes's Avatar
    Sep 27 2008
    2002 Audi A4 1.8 Q&A
    Orlando, FL
    oh wow so thats why I have to run my brights on for BOTH sides to light. So stupid, I bought the car with HIDs but they are probably 35 watt.
    Aug 26 2005
    OEM HID lamps are rated 35 watts each side, but draw more than 70 watts due to the ballast being less than 100 percent efficient. The reason the "Dipped" head light warning is ON is because the ballast isn't drawing power because it's not operating. Usually, when a HID lamp ignites then goes out after a second or so, is because the ballast sensed a circuit fault or short, and shut down as a safety measure. If there is no circuit faults, then the ballast or HID lamp is faulty. Faulty components can be isolated by swapping side to side.
    There is no relationship with "Dipped" headlight warnings and the wattage of the ballasts or lamps connected to the system.
    "Dipped" in this context means "Low-beam", and is the English Euro term for Low-beam.
    Sep 27 2008
    Orlando, FL
    And a 55 watt kit would draw the necessary power to eliminate that?
    Aug 26 2005
    Quote Originally Posted by ILikeBigBrakes View Post
    No. The lamp fault detection is not simply based on power draw. The load from a 55 watt Halogen lamp, can't be directly compared to the load from a HID ballast, powered from the same circuit.
