Results 1 to 9 of 9
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Southbend clutch finally broken in...
    Finally got the new clutch broken in and have been taken it fairly easy on it for the last 800 miles. That is until last night. I did a few launches from about 3500 rpm with esp off and ran it through 3rd gear on some side streets. The tires are actually breaking lose a little bit at launch and chirp in 2nd as well. Clutch feels strong and really engages well.
    A big for southbend. For those that don't recall, i sent them brand new Audi OEM clutch disk and pressure plate along with my flywheel and asked them to upgrade to handle ~500hp (supercharger anyone?). They replaced the material on the clutch disc with their feramic material.. Seems to work great, very satisfied customer at this point.
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Re: Southbend clutch finally broken in...
    Quote Originally Posted by ieatfishburitos View Post
    Do you have any sort of chatter?
    Jan 10 2007
    Earth
    Can you give a more specific description of what you call "chatter"?
    2013 White 911 4S
    2005 Moro Blue S4
    Veteran Member Four Rings EuroB6's Avatar
    Nov 24 2005
    2019 Audi Q7 2019 Audi Q8 2017 911 GTS
    New Jersey
    most aftermarket or upgraded clutches have exactly what he is describing...it sounds like a "chatter" like a tap,tap. When I used to have my G35 Coupe, it had it bad for the first few thousand miles and then went away. It's a bit annoying, but you get used to it.
    2020 Audi SQ7 PremPlus | Navarra Blue|Black|Black Optic Package
    2024 Audi Q7 PremPlus|White|Beige|Black Optic Package
    2017 Porsche 911 GTS Black | GTS Interior Package | Numeric shifter | GT3 RS Skirts | Kline SS Headers, Kline 200 Cell Cats, Kline SS Exhaust | Full Car PPF | 20” BC Forged MLE81 | Michelin PS4S |TechArt Springs | Vektor Performance Oil Separator | BMC Air Filter
    Jan 10 2007
    Earth
    Well about the first 300 miles I had a little bit of that type of chatter when I let off the clutch at mid to low rpm (1000 rpm or so). That seemed to disappear after about 600 miles.
    2013 White 911 4S
    2005 Moro Blue S4
    Registered Member Two Rings
    Aug 07 2008
    '04 B6 S4 - Dolphin Grey
    Collegeville, PA
    I just got my Southbend clutch installed too. The same set-up as fishburritos.
    I've only put a couple hundred miles on it so far but it's fantastic.
    Veteran Member Four Rings Monchichi8's Avatar
    Jul 03 2004
    2004 S4, 2005 Grand Cherokee Hemi
    Boulder,Colorado
    Quote Originally Posted by DapperD View Post
    So you bought brand new cluthes from Audi,sent them to southbend to take em apart and replace with the better material. Why not just go straight to them,southbend? They a re a very reputable company, their parts gotta be the same as Audi. Seems like you spent extra money that could of gone other places. Was there a specific reason for this, just curious..???
    Jan 10 2007
    Earth
    Quote Originally Posted by Monchichi8 View Post
    Southbend currently isn't able to source parts for the B6 S4. Their previous supplier no longer carries the parts. Southbend actually recommended buying the OEM parts and shipping to them.
    I sent them my flywheel and they took all the specs. They will be offering an aftermarket single mass flywheel for our cars in the future. I'm sure they will get their own clutch parts for our cars again in the future.
    2013 White 911 4S
    2005 Moro Blue S4
    Jul 03 2004
    Boulder,Colorado
    Got ya.Thanks for the info. I bet that single mass is going to be alot cheaper then the duals and a bit lighter.Wonder if it will retain stock smoothness,if you wanna call it that.lol
