Results 1 to 14 of 14
    Registered Member Two Rings
    Mar 01 2008
    Lexington, KY
    Test Pipe HELP!!!!!!!
    Well today a test pipe and cat back exhaust is or possible was being attempted to being installed. Here is the problem that we are running into. We took the exhaust back from the down pipe out. We got the 4 bolts from the cat to the turbo. We got the front O2 sensor out. How in gods name do you get the cat/down pipe out from the bottom of the car?????? I have it on car ramps in the front and jack stands in the back. We must have tried for a half an hour to get it out with NO luck at all . Once we determined this is pretty much impossible we tried to take the bolts off from the cat to the down pipe. This may SEEM like an easy task but they are rusted like no ones business and wont come out !!! ANY HELP WOULD BE MUCH APPRECIATED!!!!!!! So I can my Audi again...
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Re: Test Pipe HELP!!!!!!!
    theres bolts on the downpipe that secure it to the engine
    refer to this
    http://www.audizine.com/forum/showthread.php?t=96984
    its a pain in the ass to get to. good luck
    Mar 01 2008
    Lexington, KY
    We have ALL of the bolts off on the cat and the downpipe except the one bolting them together. I can move them like 6 or 8 inches. I just seems impossible to get it out through the bottom ...anyone have any suggestions?
    Nov 15 2007
    are you using a lift or just jackstands and jack? you need alot of clearance to get the downpipe out
    Mar 01 2008
    Lexington, KY
    I have the front tires on tire ramps and the back up on jack stands.
    Veteran Member Three Rings audidrver's Avatar
    Mar 31 2007
    CA
    Easy. Pull it out the top. If the air box is out you can pull it out the top with some maneuvering. All in one piece, cat and d-pipe. If for some reason this doesn't work you can take it half way out and then unbolt the last bolt easily. For more room on the bottom make sure the heat shield covering the cv joint is out of the way. Also make sure the end of the d-pipe is over the sub frame brace. if you can't squeeze it out then take the brace off. Anyway jut pull it out the top. If you can't do it with this info then take it to a shop.
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    why cant you just wiggle it out through the bottom? do you not have the clearance from the ground?
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
    Active Member One Ring akiodesign's Avatar
    Apr 18 2008
    Silver A4 B7
    Denver
    If its a Tiptronic you have to pull it from the top....took me about 4hrs to figure that out...
    Light Silver 06 B7 TIP 2.0T AWE Exhaust - APR Stage 2 - Eurocode Test - ITG Panel -Forge DV - Forge BOV - H&R Sways - ABT Pedals - Audi Sport Mats - All Hoen Bulbs - Blackout grill - Omori Boost - AVIC D3 - NEXT Silver CF DTM
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    Quote Originally Posted by akiodesign View Post
    that explains it...
    Nov 15 2007
    yeah because the tip trannies are so fucking big and heavy -_______-
    Jul 28 2008
    2008 A4 S-Line, 2005 BMW M3
    New Jersey
    Do you have to remove the intake to do this?
    Veteran Member Three Rings snosk8tr123's Avatar
    Jan 08 2007
    2007 Audi A4 2.0t
    Orange County
    mine was a pain too. we ended up removing the intake and taking it out from the top. putting the intake hose clamp thingy back on was a bitch as well!
    s-line titanium + plate filler + ecs smoked sidemarkers + GIAC 91 octane + Koni Coilovers + e-code test pipe + DMH electronic exhaust cutout + forge dv + bov spacer + tint + LED city light + LED license plate bulb + Yellow PIAA fogs + White Nokya Headlights + European rewiring of lights + Clear corner and blacked out housing + Red LED door lights and foot well lights + debadged + Black audi rings + Light smoke taillights + VMR vent boost gauge + DOPE sticker (+50 whp)
    Nov 15 2007
    the removal of the intake is most likely recommended. you should go buy a regular hose clamp from home depot for the intake hose because that shit is a bitch to put back in
    Jul 28 2008
    New Jersey
    do you recommend the test pipe...does it really smell bad? I have the vmr test pipe sitting in my garage
    Quote Originally Posted by supamannn99 View Post
