Results 1 to 8 of 8
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    How do I fix this weak hose clamp?
    Yesterday I was driving home and this hose popped loose. Obviously the car stopped running immediately. Lucky for me I wasn't on the freeway. After I reconnected it, I drove home. When I looked at the car again this morning, the hose had slipped almost off again just from the drive home.
    Has anyone else had this problem? How can I correct this? I do alot of freeway driving and I'm worried that it will come loose on the freeway.
    Thanks guys.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Re: How do I fix this weak hose clamp?
    replace it
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    Get a higher-end heavy duty hose clamp and tighten the $hit out it.
    Established Member Two Rings A4donkey's Avatar
    Sep 24 2005
    Anywhere
    Are you tighten it with your bare fingers?
    Use proper tools man...., tighten it harder until it never slips......
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Remove the hose and clean the oil from the inside of the hose, the throttle body and replace the clamp. If its oily in there the hose will continue to slide off.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Dec 25 2004
    Earth
    Quote Originally Posted by dirtybrd View Post
    Listen to dirtybrd!
    Jun 29 2008
    Thanks guys. There's nothing worse than a slippery hose.
    lol
    -Damon-
    Mar 21 2006
    Lakeland, FL.
    That's how I like them. Make sure to use something like brake cleaner so when some of it goes into the hose it'll evaporate.
    I'm back bitches!
