Results 1 to 9 of 9
    Senior Member Three Rings gullatec's Avatar
    Sep 10 2008
    baltimore, maryland
    Hit Curb now Big Performance Loss?
    Hey guys. I have a bone stock 04 USP 6SPD, i love it. Until last week I had to swerve out of the way of somthing and I hit a median dead on doing about 20mph, blowing out both passenger side tires.
    New Tires and Alignment
    Since then, I have noticed the car isnt performing like it used to. I remember whenever the turbo kicked in, the car would just kick it up a notch and throw me back, now, not so much. I hear the turbo spooling up, and I am not throwing any codes. I missed the vrooooooom. Any ideas?
    oh. and i do notice some boost gain, but not like i used to.
    brandon
    USP CLUB MEMBER #119 | dolphin gray | 6SP | UNKNOWN TUNE | TT225 (sitting in a box) | podi | cupra-lip | 6000k Fogs | 20% tint | slow
    Currently: Stage 1ish
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Re: Hit Curb now Big Performance Loss?
    might have a boost leak...got a vag com to check it out...
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Have you done a visual over your engine bay to see if anything was dislodged? An impact like that could dislodge something.
    Does the car drive well? I would think your control arms bent or something of that like from the impact.
    -Doug
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    yeah, my bet it you ripped boost hose or punctured something when you slammed.
    Sep 10 2008
    baltimore, maryland
    wouldnt I be throwing codes if I had a boost leak?
    brandon
    Sep 10 2008
    baltimore, maryland
    i also think my gas mileage is taking a big hit.... why?
    brandon
    Dec 18 2007
    nj
    no, you might not throw a code, i have a boost issue where the ECU is requesting up to 24xx mbar and i'm only getting 17xx mbar max, never throws any boost codes (typically i only see "upper rev limit exceeded, warranty void ;)" since i like to give it a little now and again) and i scan it almost daily with my laptop. someday i'll get to the bottom of it but it's still fast as hell only pushing 17xx.
    Oct 15 2006
    Arlington, VA
    Quote Originally Posted by gullatec View Post
    not really...i had my ic hose pop off(read: no boost at all) and didnt get a cel...
    makes me think more and more that its a boost leak..find someone w/ a vag-com and log boost...ur in the mid-atlantic area so im sure there are plenty of ppl willing to help you out if you dont have one...check the locals section...
    Edit: i lied. now that i think about it, i got great mileage when my ic hose popped off. that may be because i drove like a baby until i could fix it, but nonetheless it was pretty good.
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    bent control arms would reak havoc on millage.. check ur suspension.. and fyi small boost leaks don't show on vagcom or what not.
