Results 1 to 9 of 9
    Mar 12 2005
    MD
    Question 3rd Center Brake Light - Where to get it?
    My center LED brake light (bottom of rear window) has gone out, and I need to replace it ('02 A4 sedan)
    Does anyone have one for sale or know where I can order it online? The stealership wanted an arm and a leg for it!! Thanks in advance!
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    Re: 3rd Center Brake Light - Where to get it?
    Try a junkyard.
    GO KNIGHTS!
    Veteran Member Four Rings golgo13's Avatar
    Apr 29 2007
    Tampa Bay
    I would give you mine but i dont know how to remove it.
    SweetnLou!
    Mar 12 2005
    MD
    Quote Originally Posted by golgo13 View Post
    Let me know if you're successful and how much you'd like for it!
    Thanks in advance.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Quote Originally Posted by SiToA4 View Post
    Is it completly bad or are you getting a intermitten display of it not working?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Mar 12 2005
    MD
    Quote Originally Posted by dirtybrd View Post
    The display notice is constantly on, and never goes off...has been for the past couple months (doesn't bother me much because I have my Garmin suction-mounted to the middle of the instrument cluster).
    Mar 21 2006
    Lakeland, FL.
    Try unplugging it and plugging it back in.
    I'm back bitches!
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    if the light is constantly on, theres something wrong with your ESP
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Mar 12 2005
    MD
    If the "brake light" or the "center brake light display" is on constantly it is ESP? Doesn't make much sense if the "center brake light display" is on constantly it has anything to do with the ESP...especially when the center brake light itself doesn't work at all.
    I've tried disconnecting, connecting the LED center brake light; disconnecting, reconnecting the battery, but the message still remains and the light does not function.
    Am I missing something, or is this simply a brake light issue?
    Thanks again for the help.
