Results 1 to 13 of 13
Thread: Rust Proofing?
    Oct 17 2008
    Niagara Region, ON,Canada
    Rust Proofing?
    I have a 2006 Audi A4 and I was going to Rust proof it for this winter but i called Audi and they said that it could void the 12 yr rust warranty, and no rust inhibitor is recommended. What are your thoughts and has anyone out there done it? I don't have the warranty book (It's on order) so i don't actually know how the 12 yr rust warranty is worded. I've been told that a lot of those body and rust warranties are covered 100% for like 5years then it's a steep slope downhill on the percentage they actually cover.
    Thanks for the advice!
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Re: Rust Proofing?
    I know that they dont cover rust, they cover perforation caused by rust. So it means that your car could looks like shit and they will not cover it until it makes holes!!! A year ago I went to the dealership with my car that has a rusted spot and they told me they do nothing until it's not a hole!! So I had to fix it by myself... I thougt to sandblast the spot until it was perforated and let it rust again and then return to the dealership but I did'nt!!!
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Oct 17 2008
    Re: Rust Proofing?
    Quote Originally Posted by davidlizard View Post
    I know that they dont cover rust, they cover perforation caused by rust. .... to the dealership but I did'nt!!!
    Thanks for the heads up! That is the most ridiculous thing, I knew there was a loophole on Audi's side!
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Re: Rust Proofing?
    Am actually thinking to do it for my car for the first time this winter. I think its definitely worth it, some places are specialized in doing so.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    Re: Rust Proofing?
    speed up the process until the cover it
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    Re: Rust Proofing?
    Just coat it why not
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Re: Rust Proofing?
    I just asked around, its $70 to do here in my area. Not bad at all.
    Oct 17 2008
    Re: Rust Proofing?
    Yeah there is a place here that has been doing it since the late 70's, they charge $80 cash. He uses a non drip product that is always moving to cover any spots that may be uncovered by road debris flying up. He also encourages you to watch, while he sprays the car. When i went in to look he had a Corvette and a Mercedes that was getting done. Its a pretty sketchy place though LOL.
    I read the warranty on the 12 year rust coverage and "davidlizard" is correct they only cover BODY perforations. They says to me any body rust from the inside out. Any stone chips or scratches from the outside that causes rust would be completely on the owner. Or am i understanding that incorrectly?
    Oct 17 2008
    Re: Rust Proofing?
    I just finished reading the Krown website and talking to a local dealer and for $40 ($109.95 + tax) they do a rust proofing that doesn't void warranties. They also seem very knowledgeable and remind you yearly to get it done. They also give you their own warranty. Give it a look
    http://www.krown.com/#default
    Cheers,
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Re: Rust Proofing?
    Krown have a good reputation, I heard they are really good. I dont think they have any dealers in Montreal though.
    Oct 17 2008
    Re: Rust Proofing?
    Quote Originally Posted by jackyaudi View Post
    There are two places in Montreal that do it, see below (Got it off the Krown Site):
    Nelson's Garage 1100 Boul. Decarie Montréal, QC H4A 3H9 (514) 481-0155
    Pneu et Mecanique 6000 Sherbrooke est Montréal, QC H1N 1B8 514-254-6006
    Sep 07 2007
    Atlanta GA
    Re: Rust Proofing?
    I live near salt water do you thing this stuff will help me too
    Oct 17 2008
    Re: Rust Proofing?
    Quote Originally Posted by PCYC View Post
    I can't say yes for sure but I think so! In the Krown website (In the FAQ's section) they did a test using Electronic Rust Control system which is what a lot of sea vessels would use in salt water. They hooked a piece of steel up to the electronic device and another was coated with Krown. They then sprayed both with a salt water solution. The Krown Killed (see the pics)! You basically live with salt water moisture in the air so i would say this would definitely help you. Find a dealer off the website and ask. Call a few to make sure you get as true an opinion as you can.
