Results 1 to 8 of 8
    Senior Member Three Rings 0330QA4's Avatar
    May 25 2007
    2009 VW CC Sport, 03 A4 (Sold)
    Ashburn Va
    Intermittent Blinker
    I have had this issue for a few months now. I have ecodes with sliver coated blinker bulbs. It started with me getting a bulb out warning so I went to replace the bulb and found ti was fine, put it back in and it all worked fine. About a week later did the same so I I cleaned all the contacts even on the headlight plug. Plug it back up no problem for about 2 weeks then it came back. At this point I just dealt with it. Pulled it out again and checked it bulbs still fine. Plug it in it works this time for only two days. Anyone have any idea what the issue could be?
    Established Member Two Rings drOopy's Avatar
    Feb 14 2008
    2003 1.8TQ A4 5spd
    B-ville, MD
    Re: Intermittent Blinker
    Yeah you need to replace the bulb holder and it'll be normal again! It's a known issue, when you get the new holder, put some dielectric grease on the contact points and you're set to go!
    May 25 2007
    Ashburn Va
    Any idea where I can get this holder? The car is being traded in in two weeks and Id like this fixed.
    Veteran Member Three Rings dfresh000's Avatar
    NNJ
    did you paint the bulbs yourself ? i painted mine with aluminum engine paint and had the same symptoms for a week or two until my stealth bulbs came in. no more issues now once replaced, weird
    just a thought
    '13 Monsoon Gray S4 P+ | DSG | Carbon Atlas | B&O | Sports Diff | More Fun to Come
    '14 Monsoon Gray Q5 3.0T P+ | B&O
    Feb 14 2008
    2003 1.8TQ A4 5spd
    B-ville, MD
    Quote Originally Posted by 0330QA4 View Post
    At the dealer it's like $15 for the part.
    May 25 2007
    Ashburn Va
    Ok cool do the ecodes have the same bulb holder as US spec? Also are they the same for both sides? No I bought stealth bulbs and they worked fine for like a year.
    Feb 14 2008
    2003 1.8TQ A4 5spd
    B-ville, MD
    Which ecodes do you have? Ebay or Valeo?
    May 25 2007
    Ashburn Va
    Valeo
