Results 1 to 9 of 9
    Apr 14 2008
    a4 avant
    marlboro
    cam chain tensioner question
    hey guys,
    on an aeb cam chain tensioner- the bottom chain guide is supposed to be able to move side to side right...not alot just a little im talking about the plastic piece on the bottom of the tensioner-not the top with the black piece attached(my dog pushed me and i feel onto it in the box, dont thnk i did anything just didnt check it b4 and now im scared)
    tia john
    -vrt-
    Apr 14 2008
    a4 avant
    marlboro
    Re: cam chain tensioner question
    nothing?
    -vrt-
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Its fine
    its supposed to be able to rotate full swing (360*)
    it sits on a film of oil.
    Go install it :D
    Apr 14 2008
    a4 avant
    marlboro
    the lil plastic piece by itself?-not the tab portion
    -vrt-
    Apr 14 2008
    a4 avant
    marlboro
    thanks for the input ill be able to sleep tonite
    -vrt-
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    if you want me to check when I get home i can. I have one completely out of a working engine I can test. I think your fine, those are just the guides that the chain spins on. Should be fairly hard to "break"
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Aug 21 2008
    Poughkeepsie, New York
    While we're on this topic. I'm building an AEB head right now and one of the little plastic guides on the tensioner is worn to a point where it will not stay on. Is there a way i can replace the plastic guides or do i need to replace the entire tensioner? Also, is there a place i can get the tensioner cheap? Mine has 80k on it so it isn't very used. It also costs a lot of money.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I replaced mine and I was actually able to remove the guide from the metal clips. I was pretty worried but it works fine and no noises.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    Quote Originally Posted by shownomercy View Post
    any sludge buildup? if so its gonna be worth your time to drop the oil pan and atleast clean your oil pickup screen so it dosent clog up your oil pump
    -06 A4 2.0T
    -97 A4 1.8T
